Spreader halyards for burgees or radar reflector? - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > General Interest > General Discussion (sailing related)
Like Tree2Likes
Old 6 Days Ago
TakeFive's Avatar
Proud "picnic sailor"
TakeFive will become famous soon enough
I am thinking of installing some halyards running up to my spreaders. Might be useful for flying club burgees, or possibly a radar reflector (if a 20' high radar reflector does any good). I figured I might pop rivet a loop to the bottom of each spreader, to which I could shackle a small block for the halyard.
Have any of you done this? Got any suggestions? Where should I run the halyard - mast step plate, or stanchion base?
Formerly posted as "RhythmDoctor"
1998 Catalina 250WK Take Five (at Anchorage Marina, Essington, on the Delaware River)
1991 15' Trophy (Lake Wallenpaupack)
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 6 Days Ago
Markwesti's Avatar
Markwesti is on a distinguished road
Re: Spreader halyards for burgees or radar reflector?
Do your spreader a favor , use a nylon washer under the loop if SS . And instead of SS rivets use brass or bronze screws to hold it on . And don't spare the TefGel .
  #3
Old 6 Days Ago
jtulls is on a distinguished road
The owner of one of the boats I raced on did the same thing - rivet through the spreader and put a small block on it. We only had it on the lowest spreader on one side and then tied it off to the shroud chainplate. We only ran the line when we needed it so it wasn't in the way all the time -- quick shimmy part way up the mast to reach it!
  #4
Old 6 Days Ago
TakeFive's Avatar
My spreaders are thin aluminum, in an airfoil-like cross-section (exactly halfway up my 28' mast). Self-tapping screws do not tend to grab very will in the thin stock, and it's not thick enough to tap threads. My pop rivets are aluminum, so maybe the best route is to look for aluminum loops to minimize electrolysis.
Markwesti likes this.
  #5
Old 6 Days Ago
capta's Avatar
Master Mariner
capta is on a distinguished road
I would install the block directly to the loop, as you call it.
Simply, starboard side is for courtesy flags, port for owners, clubs, etc, if you don't have a masthead pennant..
I'd get a stay mounted cleat for the line.
facebook.com/svskippingstone
  #6
Old 6 Days Ago
TakeFive's Avatar
Eye strap or pad eye, like often used to attach straps for bimini tops.
  #7
Old 6 Days Ago
Capt Len is on a distinguished road
A proper lashing of a small SS shackle on the underside of the spreader. Shackle holds a small block. Endless lanyard to a cleat lashed to aft shroud.Q and then the courtesy flag on strbd and club burgee on the port.
Faster likes this.
  #8
Old 6 Days Ago
If you plan to hoist a typical 'round' three plate metal reflector, you need two blocks under the spreader so that the reflector doesn't chafe through the halyard return. The blocks need to be far enough apart that there's room between the hoist and return for the reflector.
In your case it would seem that lashing as described by Len above may be the way to go.
  #9
Old 6 Days Ago
aloof is on a distinguished road
I agree, do not drill into the spreader. All that is needed is a block lashed to the spreader. I have done this for years. I use some small hi-tech line for the lashing, kevcord, then a few rounds of PVC (electrical) tape to keep it from slipping down the tapered spreader and keep it tidy looking.
Any clod can have the facts, but having opinions is an art. ó Charles McCabe
  #10
Old 6 Days Ago
T37Chef's Avatar
T37Chef will become famous soon enough
Consider building your radar Reflector around the back stay. I will try to post a pic
Cheers,
Shawn & the crew of S/V Windgeist
1982 Tartan 37 CB - Hull #358
You may post attachments
You may edit your posts
Should i use a radar reflector Captain milos General Discussion (sailing related) 26 09-27-2012 01:07 AM
Radar reflector brokesailor Gear & Maintenance 9 08-14-2011 07:52 AM
Another radar reflector? T37Chef General Discussion (sailing related) 13 03-15-2010 08:01 PM
Do I need a radar reflector? Patbarbeau Gear & Maintenance 61 07-24-2009 04:49 PM
Radar reflector spreader halyard Sixbrothers Gear & Maintenance 6 05-01-2008 03:07 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
