  #11 (permalink)
Old 03-20-2008
I'm not a big fan of water-ballasted boats because water is a relatively lousy ballast medium.
First of all, it isn't particularly dense, especially when compared to the same mass of lead. Second, most water-ballasted designs have the water ballast tanks relatively high up, making the ballast even less effective than it would be otherwise. This leads to the boat having a higher center of gravity than it would if it were properly designed with a lead or cast iron keel.
Third, some smaller boats that are water-ballasted, are exceptionally unstable if you forget to fill the water ballast tanks, and that can lead to disaster if you've forgotten to fill the tanks. There are a couple of cases of water ballasted MacGregors capsizing because the tanks weren't filled or weren't filled completely, and in at least one case led to some deaths.
Yes, I know water-ballast is used on a lot of high-end racing boats... but that is for a very different reason. It is used to allow the captain to shift ballast from one side of the boat to the other, essentially a replacement for human rail meat. These boats also have a rather large keel that provides the bulk of the stability for the boat, where the smaller, trailerable, water-ballast designs do not.
If shoal draft and high stability are important, get a trimaran or catamaran or a stub-keel with centerboard, rather than a water-ballasted design.
I also think it is a bit foolish to invite the ocean on-board when a better design would not require it.
  #12 (permalink)
Old 03-20-2008
l0keman's Avatar
l0keman is on a distinguished road
Thanks, Very informative. I was looking around at large trailer sailors and saw a couple that were water ballasted. Wanted to know the skinny b/c, of course, every company that incorperates it into thier ships is gonna swear by it.
  #13 (permalink)
Old 03-20-2008
TrueBlue's Avatar
Seńor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
A water ballasted keel, weighs 64 lbs per cf, the same as the medium it's suspended in. Lead on the other hand, weighs 708 lbs per cf. Which do you think is more effective at stabilizing the boat?
True Blue . . .
sold the Nauticat
  #14 (permalink)
Old 03-20-2008
eherlihy's Avatar
Finally found the needle!
eherlihy is on a distinguished road
There's a good thread on water ballasted boats here:
ASA 101/103/104/105 Certified - Also certified in Recreational Marine Electrical Systems
  #15 (permalink)
Old 03-20-2008
Boats that are water-ballasted often lose a lot of interior stowage space or cabin space to the water ballast tanks. A cubic foot of water only weighs 60-64 lbs. A cubic foot of lead weighs about 705 lbs. That means for a boat to have 1000 lbs. of ballast, you'd need about 16 cubic feet of water or 1.5 cubic feet of lead—big difference.
  #16 (permalink)
Old 03-20-2008
artbyjody's Avatar
artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice
Send a message via AIM to artbyjody Send a message via Yahoo to artbyjody
But some could be worried about lead poisoning?...
Seriously though...trailer sailing is something that is actually considered more of day sailing - in which case, does it matter if it gets you out there and you can drag it home and it uses water ballast? For all the slack that M's get - if properly used according to instructions, it is no different than any of the 'normal' boats. Practically almost all boats can capsize, roll over etc if operator doesn't handle their boat properly.
Interestingly enough - historically speaking, boats of 100+ years ago - used water ballast and cargo weight as ballast. They managed for several hundred years criss crossing oceans - quite successfully.
Amazingly - old is new technology once again....
-- Jody
S/V "
1983, Barberis Show 38! or
Fin Keel or Shoal Keel acmecoyote General Discussion (sailing related) 11 05-06-2011 04:39 PM
reducing keel/adding fin? abacosol Gear & Maintenance 9 07-01-2007 09:32 PM
Keel Anxiety! Spang Boat Review and Purchase Forum 8 06-19-2006 03:09 PM
Wing vs Fin Keel pixurman General Discussion (sailing related) 10 05-28-2004 04:01 PM
Short Keel vs Normal SEAJM General Discussion (sailing related) 1 03-12-2003 02:13 AM
