looking for help on where to set my jib block - SailNet Community
 4Likes
post #1 of 24 Old 05-16-2015 Thread Starter
Hi, bought this Tartan 30 a few years back. This will be my third season with it(im in MI so its seasonal). The past owner was using his 100/110 jib and I switched to the 155 but have so far just left the block where it was set. Being new to sailing I am not sure exactly what I am looking for as far as where to set it. Any help on the issue will be muchly appreciated.
abrahamx is offline
post #2 of 24 Old 05-16-2015
pete
The best place to start is so that the angle of pull pulls both the leach and foot tight , then you trim as you need
beachmont is offline
post #3 of 24 Old 05-16-2015
JimsCAL's Avatar
Re: looking for help on where to set my jib block
While it depends on the relative heights of the clew, the block will probably need to be moved back. First look at the angle the sheet makes with the leech and foot of the sail. If you extend the sheet it should about split the difference and not look like its pulling in either the direction of the leech or foot but towards the middle. Then when under sail and sheeted in, slowly let out the sheet and note when the telltales start to "break". If the block is properly set, the ones at the top and bottom of the luff will break together. If they don't, move the block and try again.
JimsCAL is offline
post #4 of 24 Old 05-16-2015 Thread Starter
two great replies. That will work, thanks.
abrahamx is offline
post #5 of 24 Old 05-16-2015
Moderator
Jeff_H's Avatar
Neither of those responses will get you all that close to the optimal lead position. Most sails have at least two pairs of telltales on the luff of the sail, one roughly a 1/4 way up from the foot and the other roughly a 1/4 way down from the head, with both located roughly 18 inches aft of the luff on a boat like yours. (If you don't have them you should add them.) To check the proper lead (sheet angle) you should adjust the sail for a beat, and slowly turn up towards the wind watching both the upper and lower telesales. The windward telltale on both the top and bottom telltale should break (stops flowing aft) at the same time. If the top telltale breaks first you need to move the block forward. If the lower telltale breaks first the lead needs to be moved aft. The optimal adjustment has the upper and lower telltale breaking at the same time. This position will vary with wind strength and gradient wind conditions (variations in wind speed and direction with height above the water).
RichH likes this.
Jeff_H is offline
The Following User Says Thank You to Jeff_H For This Useful Post:
RichH (05-16-2015)
post #6 of 24 Old 05-16-2015
RichH's Avatar
Excellent post by JeffH .... as per usual.
Here's a very precise (detailed) means of accurately setting the fairlead (jib block) position that requires correctly setting/trimming the MAINSAIL first before setting the jib fairlead (jib block) position:
http://www.ftp.tognews.com/Publicati...n_the_Wind.pdf ..... see page #2, starting with: "However, I have a different approach that I believe is a bit more precise" ........
Here's the index of Arvel Gentry articles relating to setting up/ trimming, etc. a boat's sails via the use of tell tales and steering tell tales .... see article in sequence 08 - 09 - 10 - 11 Index of /Publications/Arvel Gentry Articles. This is from an 'orphan' FTP site, so I dont know how long it will remain active.
FWIW - here's another orphan website site of Arvel Gentry articles: http://arvelgentry.jimdo.com/articles/
RichH is offline
The Following User Says Thank You to RichH For This Useful Post:
sailak (05-16-2015)
post #7 of 24 Old 05-16-2015
Over Hill Sailing Club
smurphny's Avatar
Yes, having the mainsail up is essential to the shape of the jib/genoa. For example, I have a working jib with a small roach that will luff unless the main is up. I've found that if only the jib is up, it doesn't matter what the sheet angle. It will luff and the telltails will not straighten out. I've also noticed this in other boats running under jib-only.
smurphny is offline
post #8 of 24 Old 05-16-2015
Hook up a barber hauler and adjust until it sails right. Then if you want a cleat install one.
Zen is a matter of recognizing reality.
desert rat is offline
post #9 of 24 Old 05-16-2015
Moderator
Jeff_H's Avatar
I don't think that you can use a barber-hauler (or an in-hauler) on a Tartan 30. I could be wrong on this but my recollection is that the foot of the sail just touches the shrouds, and the leech is only a 2-3" off the spreader at the point that the 150% genoa is trimmed properly, and that the clew is only a few inches inboard of the lifelines at that point. In-hauling would hook the foot and open the leech, and barber-hauling would put the sail against the lifelines, neither seems very desirable.
Jeff_H is offline
post #10 of 24 Old 05-16-2015
Never having sailed I listen to Jeff with great attention. I was thinking of a barber hauler as a cheap substiture for a jib track. I read and am beginning to understand the way sailors rig sheets and lines.
New Jib Sheet Block asdf38 Gear & Maintenance 7 07-22-2014 10:38 PM
spirit 23 jib halyard block ? Southron Spirit North American Yachts 5 09-21-2012 09:41 PM
Jib halyard ends with a 4:1 block??? village idiot Gear & Maintenance 10 11-02-2011 09:40 AM
26 ranger jib lead block fishlips53 Gear & Maintenance 1 12-14-2009 04:26 PM
Sliding Genoa/Jib track block Petar Seamanship & Navigation 21 03-26-2009 12:26 PM
