Top down Spinn Furlers ... - SailNet Community
Advertise Here
Go Back   SailNet Community > General Interest > General Discussion (sailing related)
Old 6 Days Ago
RichH's Avatar
RichH will become famous soon enough
Im looking for actual user testimonials/experience of the top down spinn furlers.
Specifically Im seeking performance/usage, problems encountered such as sail cloth abrasion, continuous control line disengagement/slip, jams, reliability, etc. etc. Would appreciate seeing/reading 'the problems' and design faults encountered - by brand.
Im contemplating the furler for when single handing a 1650 sq. ft. asymm for my 'crab crusher'. I do NOT like 'snuffers'/chute scoops, etc., especially with a wet spinn.
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 6 Days Ago
Old enough to know better
miatapaul is on a distinguished road
Re: Top down Spinn Furlers ...
You might want to contact Alex over at Anything-Sailing as I am pretty sure he has used some on Guletta. (SP?)
  #3
Old 4 Days Ago
knuterikt is on a distinguished road
I don't have first hand experience with top down furlers.
But my system is similar - I have the Facnor AFX system that Facnor made before they changed to top down.
The AFX system is similar as it have a endless furler at the bottom, but the AFX uses a small Dyneema line attached mid luff to furle the sail from the middle.
I suspect that the reason for this design (opposed to top down) was the quality the anti torsion rope at that time.
I replaced my anti torsion rope last spring the improvement in the rope was noticeable.
Facnor have now also released top down - "because the AFX was to technical"..
I also replaced the furling line - rope makers have done progress in this area also.
It's important to select the correct rope for the task.
My Facnor have worked fine - but last years upgrade made it even better.
We don't leave the sail up in furled state for long periods, my experience is that we can't get i furled so tight that it won't flap in the wind.
No problems with slipping or disengaging, the problem with the old furling line was that it increased it's diameter with use/age so the friction increased.
I have seen the new Facnor model - seems to be a well designed kit.
You may post attachments
You may edit your posts
Top Down Furlers Yachtjuno Gear & Maintenance 23 07-06-2014 03:23 PM
Furlers, which one is best for my use? sailbear50 Gear & Maintenance 3 04-11-2009 09:59 AM
Double Spinn Sheets davidk Racing 25 03-07-2007 01:22 PM
dip pole spinn video mr31 Racing 2 02-07-2007 05:06 PM
Gear/Rig needed for Asym. Spinn? jrd22 Gear & Maintenance 8 02-22-2001 04:33 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
