boat repair - SailNet Community
post #1 of 4 Old 06-02-2015 Thread Starter
boat repair
looking for advice in fixing chainplate for side stays. chainplate curving up into cabintop from stress and rot. advice needed in solving problem. thanks jc boat is 1974 27ft shock santana.
slngsali1631 is offline
post #2 of 4 Old 06-02-2015
overbored's Avatar
Re: boat repair
the best fix would be to remove the chainplates and check them for corrosion. over lay pieces of 1/4" g-10 plate on to the bulkhead and glass it to the side of the cabin top and the bulkhead . then reinstall the chainplates. the g-10 should cover a larger area to cover the rot and spread out the load. new chainplates are easy to make from ss flat stock.
"GOLD RUSH" PRINDLE 16
overbored is offline
post #3 of 4 Old 06-02-2015 Thread Starter
Re: boat repair
thanks for your reply appreciate the help.
post #4 of 4 Old 06-02-2015
Re: boat repair
Remove mast & standing rigging & chainplates. (Or, remove chainplates but be real sure to rig temporary stays.)
FIX THE CABINTOP. Do some exploring and make sure there isn't more extensive deck failure to be found as well. Same for the bulkheads or whatever they were fixed into.
Once the deck has been fixed, see if you can hammer out the chainplates to the original shape and confirm they fit again. Then you take them to any decent metal shop and they should be able to make duplicates for you. Your choice of metals, which has been debating in other threads.
hellosailor is offline
Tags
boat is 1974b
plastic boat repair boatboy132 Gear & Maintenance 3 04-09-2014 11:02 AM
Infltatable boat repair or buy new ambianceack Gear & Maintenance 9 06-10-2012 09:31 PM
Boat cleat repair. dieselboy Gear & Maintenance 4 08-31-2009 12:35 PM
Boat repair blues... sailcata30 Introduce Yourself 8 08-26-2008 12:18 PM
boat repair lv4sailing Cruising & Liveaboard Forum 0 08-14-2005 11:23 AM
