Do it yourself solar panel mount! 2 Rail clamps, 1 Flat Panel TV wall mount with Tilt feature, 2 - 2 inch strips to extend the tv mount part, 1-150 watt solar panel, electrical ties for cable, some bolts and screws. It works! Its much cheaper than buying a prefab and it can be adjusted to sun direction!:angel
I need to make 3 more posts before I can upload files I used w e s t m a r i n e for rail clamps, r e n o g y solar panel and searched e b a y for appropriate tv flat panel screen mount. Make sure the screen mount can handle the solar panel weight go with a 60 inch or greater. Mount can be purchased for about 20-30 bucks, rail clamps whatever west charges. Sorry about no picks have to write more posts I guess.
Give me about a week to 10 days and I will get pics, parts, locations and post it on a web site. Im not real good at using drawing software. Pics are worth a thousand words!
That looks really nice.Thanks for the idea, and pic .Been buying up some stainless bimini frames and brackets of cl when they are cheap to do something like that.
Gary, did that solar panel come with that rigid frame or did you build it yourself? Details man! I want to build a rail mount frame that I an flip up and down as well as remounting it over the Bimini. All suggestions and advice are welcome!
George, the panel came from Home Depot with a rigid, aluminum frame. I added some aluminum cross members that came from Home Depot and then attached the bimini parts. When I get to the boat this weekend, I'll shoot some HD video close-ups so you can see how everything is put together. I completed the entire installation, wiring and all, in less than two hours, and I'm old and slow.
Sorry I didn't get around to this until today, but here's the video of the solar panel mount.
The solar panel was purchased from Home Depot, it's a 100-watt panel that is encased in an aluminum frame. I attached a pair of aluminum angle strips to the base of the frame using stainless screws and nyloc nuts. All other parts were purchased from Marine Depot and are nothing more than Bimini top parts that were very inexpensive. I covered the corners of the panel with some plastic insulation that I removed from an old electrical cable, then glued the strips to the edges so I wouldn't inadvertently part my hair with the sharp edges. I attached the back edge of the panel to the back stay using a wire tie and another short strip of insulation to prevent chafing. It works great and provides a very stable anchor for the panel.
I like that! It looks easier than mine to put together. So, the bottom of the bimini post comes like that? Ready to be attached to the rail? Oh, and your the Morgan Man!!! I did one of those introductions with where I sail and boat model (all good to go just have to get some new sails and furlers as weighing 100 lbs does not give me a lot of leverage)! Thanks for the video as I am a visual learner.
Gary, thanks for posting the info on your mount. Clever.
However, I have doubts about that controller. Based on the price and the description, I'm sure it's a simple shunting type, not PWM and certainly not MPPT.
I checked the specs on mine this morning, it does exactly that - cuts off a 14.2 and turns back on at 13-volts. And, it's a 7 amp controller, not 8 as I earlier thought.
Gary
Related Threads
1.7M posts
173.8K members
Since 1990
