Where did the air go? - SailNet Community
post #1 of 9 Old 06-30-2015 Thread Starter
Skipper Jer's Avatar
Replaced the diesel fuel line between the tank and the filter. That is all I did, didn't bleed the line, didn't prefill the line. No precautions taken to eliminate the air in the line. That was about 2.5 hours of run time ago. So where did the air go? Shouldn't the air have been sucked up into the engine by now starving it for fuel? Filter bowl is full. Runs fine.
Nor'sea 27
Don't re-accommodate me, Bro
And the trees are all keep equal by hatchet, axe and saw...RUSH
I invented a new word today, plagiarism.
Skipper Jer is offline
post #2 of 9 Old 06-30-2015
Re: Where did the air go?
Self-bleeding?
Mark1948 is offline
post #3 of 9 Old 06-30-2015 Thread Starter
Self bleeding? It's a Yanmar 2gmf20. Would there be some sort of fitting/device on the fuel filter?
Nor'sea 27
post #4 of 9 Old 06-30-2015
travlin-easy's Avatar
It's likely in your fuel filter, but it may have emulsified and burned off.
all the best
Gary
travlin-easy is online now
post #5 of 9 Old 06-30-2015
nccouple's Avatar
Air will work it's way out by its self. I regularly service heavy equipment. Just keep the pedal to the floor after changing the filters. Most of the time they smooth out after about 10 seconds. Then occasionally you gotta bled them.
oursailingadventures.com
nccouple is offline
post #6 of 9 Old 06-30-2015
A finite quantity of air can be digested under the right conditions. It's much worse if you've got a leak in your fuel lines and an unlimited amount of new air getting in.
IStream is offline
post #7 of 9 Old 06-30-2015 Thread Starter
Here I've been under the impression any air would stop the engine.
Thanks all for clearing this up.
Nor'sea 27
post #8 of 9 Old 07-01-2015
Master Mariner
capta's Avatar
That far up the system, it may be in the top of your primary or it can trickle through the lines and go out the return lines. I wouldn't worry after running for that long.
I can often change the primary w/o bleeding the system, though more rarely the secondary on the Perkins.
facebook.com/svskippingstone
Our Videos;
capta is offline
post #9 of 9 Old 07-02-2015
JimsCAL's Avatar
Probably back to the tank via the return line. You got lucky.
JimsCAL is offline
Air Tools and Compressed Air rockDAWG General Discussion (sailing related) 17 05-27-2013 01:23 PM
Light Air or Heavy Air - What's Most Frustrating? Sabreman Seamanship & Navigation 26 07-16-2012 06:15 PM
Whats quieter Air X with spreco blades or Air Breeze? Mariner777 Gear & Maintenance 4 07-19-2011 05:52 PM
Climma air vs Cruize air 59paul Gear & Maintenance 0 11-04-2009 11:09 PM
Air Force suitable for light air racing conditions? First Love Gear & Maintenance 0 11-14-2001 08:51 AM
