Cal25 rudder shaft - SailNet Community
post #1 of 13 Old 07-08-2015 Thread Starter
Cal25 rudder shaft
I have a 1969 Cal 25 and noticed that when I pull the tiller to one side I have about an 1/8th inch of slop in the shaft housing going through the boat is this normal ?
tom_beckstedt is offline
post #2 of 13 Old 07-08-2015
No. The shaft in the Cal25 is just a fiberglass tube and they've been known to develop slop.
I've heard of people pouring graphite thickened epoxy into the space to tighten them up.
SJ34 is offline
post #3 of 13 Old 07-09-2015
Senior Moment Member
SloopJonB's Avatar
Re: Cal25 rudder shaft
If you do that, be sure to remove and very thoroughly wax the rudder shaft first - like 7 or 8 times.
If you don't you will simply epoxy the shaft to the tube.
Also, once the epoxy has set you may find you need to lap the shaft & tube with valve lapping compound to loosen it up slightly - they can get so perfectly fitted that a film of water between them can cause a sort of hydrolock situation.
SloopJonB is online now
post #4 of 13 Old 07-09-2015
overbored's Avatar
never use valve grinding compound or emery cloth on a bronze or stainless shaft. the sapphire in the compound will imbed in the shaft and bearing material and continue to grind away at the shaft even after you have cleaned the shaft. if you have to lap the the surfaces then Pumice mixed with some oil is best because the pumice will continue to break down and not imbed
"GOLD RUSH" PRINDLE 16
overbored is online now
post #5 of 13 Old 07-09-2015
SloopJonB's Avatar
I could maybe see that on a soft bronze shaft but S/S? why doesn't it happen to steel &/or S/S valves, for which it is specifically manufactured?
post #6 of 13 Old 07-09-2015
overbored's Avatar
the valves in an engine are hardened with even harder valve seats. stainless steel rudder shafts are 304 or maybe 316 material and it is not heat treatable and very soft . the cutting compound will imbed in the surface and continue to grind away at the bearings. it also will imbed into the soft plastic resin of the shaft tube.
if you want a pre made compound for soft materials then Timesaver Lapping Compound Yellow Label and Green Label Compounds, non imbedding lapping compound, manufactured by Micro Surface. but it is just pumice in oil
post #7 of 13 Old 07-09-2015 Thread Starter
So your basically saying there shouldn't be any slop, Will have to hall out to do repairs can it wait till fall?
post #8 of 13 Old 07-09-2015
SloopJonB's Avatar
It can wait as long as you are willing to put up with it.
post #9 of 13 Old 07-09-2015
Maybe a length of string in candle wax wrapped round and round and pushed down with a popsicle stick. Or maybe just the popsicle stick for a real high tech fix.
Capt Len is online now
post #10 of 13 Old 07-10-2015
Lake Superior Sailor's Avatar
I believe the Cal's were built with this slop and is nothing to worry about..Don't fix it if it's not broke!...Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
Rudder Shaft seahorse 2 Islander 0 04-11-2015 06:38 PM
CS-36T rudder shaft soyuz General Discussion (sailing related) 0 07-03-2014 11:24 AM
rudder , shaft and engine out, then what? GaiaOrion Gear & Maintenance 2 02-03-2014 10:08 PM
Rudder Shaft Lube chs1517 Gear & Maintenance 4 11-15-2009 10:59 AM
Dufour 32 Rudder shaft dufour32 Dufour 1 08-10-2009 04:37 PM
