Solar Panels in High Wind - SailNet Community
 8Likes
post #1 of 31 Old 3 Weeks Ago Thread Starter
Assume that solar panels are mounted on an arch. It seems that high winds could easily damage solar panels. So, a good installation with high winds in mind should be made. Are there any experiences where solar panels were damaged in high winds? Any comments on installation that remains secure in high winds?
davidpm likes this.
gbgreen59 is offline
post #2 of 31 Old 3 Weeks Ago
Morgan 33 O.I. Perryville
travlineasy's Avatar
Re: Solar Panels in High Wind
Mine is mounted on the stern rail and anchored in the center of the frame to the back stay. It has been exposed to 60 MPH winds several times with no damage whatsoever. I suspect a lot of this depends upon how the frame is constructed and how securely it is mounted.
All the best,
Gary
travlineasy is offline
post #3 of 31 Old 3 Weeks Ago
TQA
Bombay Explorer 44
TQA's Avatar
Mine are on a rear arch with a center pivot. I have ties front and back to adjust the angle to follow the sun.
They too have survived 60 knot squalls in both horizontal and tilted mode.
TQA is offline
post #4 of 31 Old 3 Weeks Ago
Master Mariner
capta's Avatar
As an alternative to an arch, this has worked out very well for us. So far winds have probably not exceeded 65 knots, but unless they are hit by something, I don't see why they wouldn't survive hurricane force winds.
facebook.com/svskippingstone
Our Videos;
capta is online now
post #5 of 31 Old 3 Weeks Ago
Vagabond in Training
Livia's Avatar
I haven't heard of anyone losing them except from debris. I'm sure it is possible but unless the install is really shoddy, or you get hit by a bad arse hurricane, probably not worth worrying a lot about.
Livia is offline
post #6 of 31 Old 3 Weeks Ago
aeventyr60's Avatar
Some close up pictures of a solar panel mount being fabricated. Will be very strong.
Temptation Eyes 018.jpg   Temptation GIN PALACE 041.jpg   Temptation GIN PALACE 039.jpg   Temptation GIN PALACE 043.jpg
jerryrlitton likes this.
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
post #7 of 31 Old 3 Weeks Ago
Not Finished Yet
RainDog's Avatar
Fwiw - When we had our RV, people on the forums attached panels to their roof with 3m VHB tape. I could not believe that would hold at 85 mph on the highway, but never heard of a failure.
Pacific Seacraft 34 #142
RainDog is offline
post #8 of 31 Old 3 Weeks Ago
Omatako's Avatar
Any solar array mounted reasonably horizontal (as most are) present a very small cross section to wind.
We have ours on a radar arch, contained in a light SS angle-section frame and bolted to the top of the two arch sections. We had Hurricane Pam visit us not too long ago and while we never got hurricane level winds, we have at least 60 knots across our anchorage and no damage sustained. Solar panels in their own right are actually quite strong.
Any sensible mounting arrangement will probably be OK in winds that will scare the average sailor.
Arthur C. Clarke
Omatako is offline
post #9 of 31 Old 3 Weeks Ago
Less Senior Senior Member
That stuff is so strong you literally need to 'cut' it by using a flexible wire and a sawing motion to get it off once bonded.
seaner97 is offline
post #10 of 31 Old 3 Weeks Ago
MarkofSeaLife's Avatar
Dock
They are horozontal.
Mine when through Hurricane Gonzalo fine.
Mark
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
SOLAR JACK solar panels? christian.hess Electrical Systems 0 11-13-2013 09:51 PM
Solar deck instead of solar panels ulferlingsson Gear & Maintenance 34 01-31-2013 05:03 AM
Solar panels vs. wind or forget it? wannabsailor General Discussion (sailing related) 46 01-09-2013 02:30 PM
Anyone bought solar panels from Sun Solar? justonemoreproject Electrical Systems 1 04-18-2012 05:08 PM
Solar Panels bottleinamessage Jeanneau 0 08-16-2007 07:10 AM
