08-11-2006
From your description of the change to your centerboard, did you change the shape of it at all?
If it was previously sliding down forward and aft, and is now pivoting from a forward pin, then the center of the area exposed may have moved aft, shifting the Center of Lateral Resistance aft, which should make it easier to tack, not harder...but if you've made other modifications to the centerboard design, you may have upset the sail vs. water balance of the boat.
