Intake Through hull for Marine Head - SailNet Community
post #1 of 5 Old 08-20-2006 Thread Starter
This Spring we noticed that over the winter water in our marine head had frozen, cracking the back of the fixture. When I went to replace the broken head, I found that, even with the seacock closed, water continued to flow from the intake line, indicating that the seacock was not functioning right. It wasn't closing off fully.
Question: Do I need to replace the seacock or is this just the result of lack of maintenance. Can they just be cleaned or something? The seacock is bronze, I think - I guess it could be brass. I'm kind of learning maintenance as I go...is this kind of thing common?
dave6330 is offline
post #2 of 5 Old 08-20-2006
Dave - if there was water in the seacock that froze and expanded, yes, the pressure from expansion could have cracked the seacock. Particularly if the water was trapped in a seacock in the 'closed' position - sometimes this happens even down here in the warmer 48, with boats in the water with seacocks closed.
BTW, as part of your damage control kit you should have some soft wooden plugs of the appropriate diameter to fill the hole if a seacock breaks (or blows out), some folks put the plug right next to each seacock.
eryka is offline
post #3 of 5 Old 08-20-2006
Generally, the plugs need to be kept DRY. The idea behind the softwood plugs is that they will swell and remain in the hole as a plug as they absorb water. If the plugs are already wet, they will not swell, and will not properly serve their function.
sailingdog is offline
post #4 of 5 Old 08-21-2006 Thread Starter
We do have the appropriate sized wooden plugs tied with cord next to all of the thru hulls where they do, indeed, stay dry. We may be new at this but the previous owner was a good sailer and maintained the boat well. God bless him!
If the valve were damaged due to freezing, wouldn't there be a seep from the valve into the bilge? We have the kind of valve with the lever off to the side that turns a barrel inside the valve body allowing water to pass. Seems kind of foolproof. I was wondering if these wear out? For now, CIRRUS is on the hard so I'm not worried, but I'm concerned about what I need to do before I put her back in the water.
V/R
dave6330 is offline
post #5 of 5 Old 08-21-2006
Not necessarily, it would depend on where and how the valve was damaged. By "turns a barrel" do you mean it turns a ball or a tapered cone? The design of the two valves is quite different.
If you are able to remove the seacock from the thru-hull, I would take it off and inspect it—then replace it if necessary. This should be fairly easy to do since Cirrus is on the hard. It is also better to be safe than sorry, since replacing it while the boat is in the water will be much more difficult.
Glassing hull GreenEarth General Discussion (sailing related) 18 06-20-2009 12:52 AM
High Tech vs traditional-Comments? Pangaea General Discussion (sailing related) 38 08-07-2007 02:07 AM
Hull speed and wide sterns Jeff_H Boat Review and Purchase Forum 24 11-22-2006 12:58 AM
hull construction cgha33 Boat Review and Purchase Forum 4 05-23-2003 08:11 PM
Re-joining inner/outer hull section ColinLuthardt Gear & Maintenance 0 10-26-2002 08:19 AM
