mast steps - SailNet Community
post #1 of 2 Old 08-21-2006 Thread Starter
mast steps
Hi; I'm about to install steps on the mast; it's a kenyon mast with a seam on each side. Anyone have any experience with this? Should I drill the holes away from the seam? this would give me a little offset, as the mast curves in at the front. Also I'm tapping and using stainless steel screws; I've heard locktite will help prevent electrolysis; is there any special purpose thread compound that might work better? thanks Eric
egregerson is offline
post #2 of 2 Old 08-21-2006
I don't think you would have a problem drilling and tapping on the seam.
Locktite is good for preventing corrosion but there is a new product which is a combo of tef-gel and locktite that I've heard good things about.
knothead is offline
Deck vs. Keel Stepped Masts Envirella Gear & Maintenance 10 11-29-2009 11:06 AM
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
If you were going to install mast steps... RobHoman Gear & Maintenance 2 01-28-2002 06:40 AM
