  #61 (permalink)
Old 08-20-2008
Don't store the propane canisters below. They're prone to leaking, especially after being used once...
The best storage system for them is to make a "propane locker" for them out of Schedule 80 PVC pipe. The locker is basically a section of tube with end cap welded on the bottom, that has had a large 1/2" hole drilled in it. The tube is then fastened to a stanchion or the lifelines and the propane tanks are dropped into it. Another end cap is put over the top and fastened either by a hole drilled with a 1/4" fast pin or a piece of bungee cord.
Originally Posted by Joesaila View Post
Just finished a second 150 mile sail around the outer cape to Nantucket, M.V. and the canal. Each trip lasted a week and there were 4 adults on board. The non pressurised [2 burner Origo] lasted on a single fill up at the start and there were no problems. [I would never try to fill it while sailing] Its not difficult at all to see the blue flame and the heat was very sufficient. I am looking for a way to make bread. [we don't have an oven, but I'm certain it can be done] We do have a propane grill for the rail and I would like to find out about safely stowing those small tanks below. Is there a locking box or system anyone is aware of?
  #62 (permalink)
Old 03-08-2010
L124C's Avatar
L124C is on a distinguished road
Huh?
Originally Posted by TrueBlue View Post
A close friend and I were anchored in our separate boats off Fort Adams 2 seasons ago, to watch the Newport Folk Festival. My wife and our two 20-something kids were on True Blue, close by his 25 y/o Pearson 33, while he and his party guests got pretty wasted during the course of the afternoon.
Close to 5:00 pm, he decided to cook some food, pumped up his pressurized tank, but was distracted by the encore performance and went up into the cockpit. Apparently, his valve was open before he pressurized the tank - overflowing the burner cup and sending alcohol fuel down into his bilge.
No one knows for sure how much time passed before he attempted to pre-heat the burner. But when he did, the flame ignited the burner and quickly spread down into his bilge. Flames began to melt the fiberglass interior hull and ignited the wood sole, cushion fabric, cabinets and bulkheads. As the hundreds of anchored boat people watched, black smoke & flames were blazing from the ports & companionway, while most of the guests jumped off the boat. The captain and a friend however, stayed onboard and eventually put the flames out with water & flour - only after pulling up every floor board.
The boat was nearly totaled, took 2 years to restore, and is still unfinished. The owner since then, installed a propane system to current ABYC safety standards. Modern alcohol stoves may be safer today, but onboard alcohol as a cooking fuel is still terrifying to me. I have yet to hear about a propane fire in this area, but plenty of alcohol fires occur each year - including one we had on a former boat.
A few questions: If the burner was open, how did he achieve the required pressure when filling the system? Wouldn't happen on my pressurised alcohol stove. I would see I wasn't getting to 20lbs, and know something was wrong. Why didn't he smell the fumes when he entered the Galley to light the stove? This much alcohol in the Salon of a boat is going to have a significant odor. If it doesn't, the alcohol has evaporated already (which it does fairly rapidly). On my stove, you would have to pour at least two gallons of fuel onto the burners to allow it to flow down, fill up the bottom of the oven, overflow the containment pan below the stove, and flow into the bilge. No offense to your friend, but I believe your example is not an indictment of pressurised alcohol stoves as much as it is skippers who don't use common sense. He could have made similar mistakes with Propane, and everyone could have been BLOWEN off the boat! Quite simply, you have to pay attention when working with ANY fuels on a boat. Given the nature of the event and mistakes made, I wonder if the problematic alcohol wasn't in the stove at all, but in the Skipper!
Hillerange Alcohol Stove Fittings halyardz Gear & Maintenance 22 01-12-2011 11:18 AM
alcohol stove KenD Gear & Maintenance 18 11-12-2009 07:04 PM
Perko alcohol stove -- help! grey99 Gear & Maintenance 7 10-06-2009 01:51 AM
which model alcohol stove? S2 MONOBOY Gear & Maintenance 1 01-28-2004 01:55 PM
Need info on Pearson 30 alcohol stove pilot2sailor Gear & Maintenance 3 01-08-2004 12:01 PM
