Volunteer Article Editors with HTML experience needed - SailNet Community
post #1 of 1 Old 08-22-2006 Thread Starter
Administrator
administrator's Avatar
SailNet is in the process of moving all of the Sailing Articles into a new section in the forums where users may comment on and rate articles and authors. A number of the SailNet articles need some minor HTML changes for them to display correctly when shown in the forums section of the website. The forum software has a zero tolerance for missing or incorrect HTML tags and we are seeking a few volunteer editors that are fluent in the HTML that will assist us in making minor changes to some of the articles to insure their proper display.
Volunteers should be fluent in HTML, understand HTML tags, TABLE, TR and TD tags.
As a Volunteer Editor you will be granted special access right in the Articles Section that will allow you to edit the articles that we've migrated over from the old system.
If you feel you are technically qualified from an HTML standpoint to assist us in editing these articles, please contact support@sailnet.com
No sailing experience or knowledge of sailing terms is necessary, just HTML experience. Volunteers should be able to demonstrate websites or pages created in HTML. Some of these articles contain very complex HTML tags so you definitely need to be experienced.
Thanks in advance.
The SailNet Support Team
administrator is offline
Closed Thread
Head experience needed Irwin32 Gear & Maintenance 2 10-17-2003 08:58 AM
Experience Needed will2455 Crew Wanted/Available 4 10-28-2002 02:34 AM
