Asymmetrical Sail - SailNet Community
post #1 of 3 Old 11-24-2015 Thread Starter
Asymmetrical Sail
Can someone tell me the difference between an asymmetrical sail and a genoa. Is it the weight of the sail or ? Thanks
weephee is offline
post #2 of 3 Old 11-24-2015
Re: Asymmetrical Sail
If by "asymmetrical sail" you mean an asymmetrical spinnaker, then that sail is meant for going downwind only. It's usually lighter, yes, but it's also cut rounder (more parachute-like) and is not connected along the forestay. The genoa is cut much flatter, is connected along the forestay, and yes, us cut heavier. As a result, it can be used to sail upwind and downwind, though you'll get better performance downwind with a spinnaker.
jeremiahblatz is offline
post #3 of 3 Old 11-24-2015
Assyms (typically a type of spinnaker as jb says above) are usually nylon, whereas a Genoa will be dacron or more exotics if racing. That immediately changes the 'weight' of the material.
The sails have different job descriptions too.. the Genoa is usually the largest headsail you might have, with the smallest usually referred to as the 'jib' or 'working jib'. Smaller still would be a storm jib. You can sail any point of sail with these, but once you start reaching off they become quite inefficient unless it's 'honkin'... Genoas/jibs work best when chosen (size-wise) for the conditions and when sail beam reaching up to close hauled.
Assym spinnaker are usually optimized for beam to broad reaching, full cut but will still suffer when sailing towards DDW as they become blanketed by the mainsail. Biggest advantage and probably the reason for their popularity over a conventional symmetrical spinn is that they do not need a pole, nor the rigging and handling that goes with that. When combined with a 'snuffer' they can be pretty easy to set and douse (as long as the snuffer rigging doesn't get snarled up)
We have both types of spinnaker, and will run the symmetrical if gybing is likely to be necessary, choosing the asymm when we're pretty confident it's a one-tack reach where we're headed.
Faster is online now
Asymmetrical Color smurphny General Discussion (sailing related) 12 08-03-2014 04:15 PM
Asymmetrical Warfare Ajax_MD Learning to Sail 9 08-19-2010 01:33 PM
Asymmetrical sail measurement Greguk Gear & Maintenance 3 04-23-2010 09:22 PM
Asymmetrical spinnakers petegingras Gear & Maintenance 17 12-27-2007 03:32 PM
asymmetrical or UPS ? henryvand Gear & Maintenance 0 10-18-2001 04:52 PM
