01-27-2010
smillinjack
Originally Posted by texas bob
Me again:
Maybe you can help me. Does your Starwind have a combonation keel/centerboard? If so, do you know how to change the line on the centerboard up-haul from INSIDE the boat? Or do you have to do it from outside? Also, my backstay is "sloppy " loose and the turnbuckle is turned all the way tight. What good does the backstay do, or am I using it wrong? Thanks, Bob
My 22 has a swing Keel and I had a boatyard replace the keel pin and plates and also the cable. The keel cable has a clevis at the bottom end that attaches to the trailing edge of the keel with a bolt though it. If the boat is on a trailer you may be able to let the keel down far enough to see it and replace it. On the back stay I don't think that it has to be real stiff, you could have 3 or 4 inches play, that's where you could pull on it and move it 3 or 4 inches , not sagging 3 or 4 inches. The back stay helps keep the mast stable , it also takes the strain off the mast step. Hope that was some help.
