-   -   ferro boats (http://www.sailnet.com/forums/general-discussion-sailing-related/23058-ferro-boats.html)
feta 09-16-2006 04:46 PM
ferro boats
hi im looking at buying a ferro boat.what are the pitfalls and are there any pluses?????.nice boat with 6-4 headroom ,which i need .very basic .to go round the world will need a lot of electronics.thinking of putting it up on the dry and surveying it .any ideas what to look for
Rockter 09-16-2006 08:02 PM
I don't think you can insure it.
mstern 09-16-2006 08:46 PM
Why do you want a ferro boat? They were relatively popular for a very short time about thirty years ago and then pretty much disappeared. From what I understand, they disappeared for good reason. Westsail was the primary manufacturer, and they sold a lot of boats as unfinished hulls for the do-it-yourself market. As a consequence, the quality of the boats out there varies tremendously. Ferro as a building material has the benefit of being really inexpensive; this keeps the cost of the new boat way down. For you the used boat buyer, this is almost meaningless as you reap none of those benefits. Cons? poorly constructed interiors, uneven quality fittings, very heavy displacement (i.e., slow), poor resale value. What happens when you hit cement with a hammer? Imagine hitting your cement hull on a rock... I could go on, but you get the picture. I would guess that one of the big attractions of this boat you are considering is its low price; well, the price is low because the demand for ferro boats is low too. If you are seriously considering buying the boat, ask if the interior is a factory job or done by an amatuer. Check the wiring and plumbing carefully; if they too were done in the backyard, they may be suspect. I have seen enough crappy electrical work done by professionals in factories; I shudder to think what an enthusiastic but untalented amateur might come up with. Unless you are very handy, have a lot of time, and enjoy major projects, I would avoid ferro boats. There is a world of inexpensive fiberglass boats out there with 6'4" headroom capable of going around the world.
Johnrb 09-16-2006 10:20 PM
FWIW - Westsail did not build ferro cement boats. Their boats were glass construction.
sailingdog 09-18-2006 08:26 PM
Ferrocement boats are often considered uninsurable because the quality of their construction was very variable, as many were home-built. They were considered a cheap way to construct a boat, but if the proper materials weren't used, they have a lot of problems. I have seen some ferrocement boats that were well-executed and quite beautiful, and I've seen many more that were disasters waiting to happen. YMMV.
Finding a surveyor who has experience in Ferrocement construction is likely to be difficult.
yotphix 09-18-2006 09:36 PM
Mstern: what happens when you hit GRP with a hammer? Ok now how about wood? Now tell us what light houses are made of. Cement really isn't dumb as a building material and add to the list of benefits easy to repair any where in the world.
Now for the electrical and plumbing on the vast majority of inexpensive fiberglass or any other material boats. Lots done by "handymen". Automotive and household materials.
I'm no ferrobooster but as I understand it, low quality galvanized armature wire was the big problem with many homebuilt ferro hulls. If you can find a surveyor who knows them and it checks out then why not ferro. Cheap does sometimes translate to good value if you're careful.
Jeff_H 09-19-2006 10:27 AM
You might want to look at the rather long and very detailed discussion on ferrocement boats over at the Cruisers Forum.com. http://www.cruisersforum.com/forums/...ht=Ferrocement
Its a good thread with people weighing in on both sides, including a number of people who actually own ferrocement boats. My opening comments were as follows:
My take on ferro-cement is that it is, in fact, pound for pound the weakest of all of the commonly used boat building materials. Ferro-cement operates by the same principle as fiberglass, in other words, a high tensile strength reinforcing held by a high compressive strength, low tensile strength cement. The cement in ferro-cement ideally is a high strength Portland cement with a very fine sand aggregate. The cement in fiberglass is polyester, vinylester or epoxy resin. The tensile reinforcing material in ferrocement is steel (sometimes with glass fiber added), and in fiberglass it is glass fibers in a variety of forms, kevlar, carbon and all kinds of new variations on these materials.
Ferro-cement's weight comes from a number of sources. First of all, no matter how small the boat, there is a practical limit to how thin ferro-cement can be. Ferro-cement needs to have a minimum thickness in order to have sufficient depth of material to protect the reinforcement from moisture. Because of this boats below 40 to 45 feet are generally considered too small to use ferro-cement efficiently. (i.e. their hulls, and deck structures weigh more than they would in some other material.)
The implication of the weight issue is not readily obvious. At the risk of sounding like a broken record, Weight in and of itself does nothing good for a boat. It does not make it stronger, or more comfortable or more stabile. Weight does increase the stress on the various parts of a boat. It increases the size of a sail plan required to achieve a particular speed. It increases drag and typically means that for a given draft a boat will have a less efficient keel (i.e trading off greater drag for the same amount of leeway.)
In order to carry more sail area the heavier boat with equal or less ballast stability needs greater form stability, which comes at the price or a choppier motion and greater drag, or greater ballast or deeper ballast which adds more weight and drag and perhaps depth.
To keep the weight down, many ferro-cement cement boats have reduced ballast ratios when compared to other construction techniques. This means that they need more sail area because of their weight but they can't carry more sail area because of reduced ballast ratios, at least not without using lower aspect rigs which are by their very nature much less efficient on almost all points of sail.
This is further complicated by the fact a higher proportion of the weight in a ferro-cement boat is carried in the in the topsides (and sometimes decks). This means a high center of gravity which has a variety of implications; reduced stability, wider roll angles, smaller angles of ultimate stability, and more prone to excitation rolling (which may be slightly offset by the greater inertial moments due to weight).
This added hull and deck weight, larger sail plan, and perhaps greater ballast requirement to carry the sail plan make these boats a less than ideal choice for distance voyaging for a variety of reasons. Any given design can only safely carry so much weight before it begins losing safety, stability and sailing ability. If excess weight weight is required for the hull, deck, rig and ballasting, there is less weight available to carry food, stores and gear. For a given payload, a bigger more capacious boat is required. And since displacement is a major component in determinging the amount of anticipated maintenance costs (affecting sails and deck hardware size, ground tackle and dock lines, engine size and fuel consumption, down to even simple things like the amount of bottom paint required), these boats that are become expensive to maintain as well.
Then there is maintenance costs. In a study performed some years back looking at the life costs of various materials, ferro-cement-cement came out as the highest maintenance cost material (if I remember worst to best was ferro-cement, steel, conventional wood, aluminum, fiberglass, cold molded wood) Of course as with any generalized study there will be case by case exceptions and given the comparatively small sampling of non-FRP boats the results could easily been skewed by a few bad apples.
Other problems with ferro-cement are the difficulty of connecting things to it, and prevention of rot in wood in contact with ferro-cement. The difficulty in bolting to ferro-cement is that ferro-cement hates localized loadings. It’s hard to glue things to ferro-cement. secondary bonds are greatly greatly weaker than primary bonds.
Then there is the market value thing. ferro-cement does have a reputation in the States that does not match the comparatively high regard that it is held in other countries. Some of this is just plain unfair prejudice but some of this comes from real shortcomings in the materials as noted above. A well-built ferro-cement boat can be a reasonably good cruising boat. But the image of the crudely finished ‘hippie’ built cement and rust buckets still clouds the perception of ferro-cement for many North Americans.
The other problem is telling whether the boat that you are looking at is a good boat. It is very hard with non- destructive survey techniques to tell whether the original work was done well and is in good condition. While sounding will reveal any major separations in the cement to reinforcing bond, it does little to determine the affects of fatigue, poor curing practices or cold joints. With Ferro-cement it is particularly important to maintain the ferro-cement parts in good condtion. That can be very significant. People who buy boats because they are priced well below the market, often are overly frugal or just plain do not have the money that it takes to properly maintain a boat. An otherwise good Ferro-cement boat left to poor maintenance and miss-handling can quickly become a poster child for why North American’s don’t trust Ferro-cement
To me the real cost of owning a boat is the difference between what you paid for the boat, the cost of upgrades and maintenance and the price that you can get when you sell the boat. The problem with a lot of low value boats is that the sales price is always limited no matter how much you put into the boat. This too works against ferro cement boats.
I guess my conclusion is if you are strictly looking for an initial up front cost boat and don't mind putting some sweat equity in, and you can look past the sailing shortcomings, and you actually find one that was well built and well maintained, a ferro-cement boat might work out fine for you. For most of us, they do not.
Respectfully
mstern 09-30-2006 11:42 AM
Ooops
It looks like my memory is more faulty than ever; it wasn't Westsail that made the ferro boats back in the day (although they did look like it). Yotphix, you make a good point about other materials. My point was not that wood or fiberglass is invulnerable to smashing on a reef, just that while cement is a very strong material, it is generally more brittle and less likely to "flex" than wood or even fiberglass. And while you can find cement anywhere in the world, what little I know about ferro boat building leads me to believe that you can't use just any cement. Maybe ferro boats are more popular elsewhere and there are skilled craftsman available. However, if the boat were to be used primarily in the good ol' US of A, I would rather depend on finding skilled fiberglass workers than experienced ferroboat builders.
