Smelly Sheets (not the ones you sleep on) - SailNet Community
Blogs
Old 09-23-2006
bbistis's Avatar
bbistis is on a distinguished road
After a while sheets start to smell (wet,dry,wet,dry...). Can I just throw them in the washer/dryer (low settin) to refresh?
Old 09-23-2006
Soaking them in a large tub or bucket filled with some warm water with some fabric softener added may help. I don't think putting them in the washer or dryer is a very smart idea. The action of the washer/dryer mechanism may cause some problems... but YMMV.
Old 09-23-2006
knothead's Avatar
I've done that. It works but you will spend some time untangling them when you're done. Might be better off just doing it by hand in a bucket.
Old 09-23-2006
bbistis's Avatar
Did you use regular home washer & dryer, or industrial type?
Old 09-23-2006
TXS-ALAMO is on a distinguished road
I've found that you can use a clothes washer (the bigger the better) and avoid tangling the lines if you put them in a large open weave mesh bag. They come out clean and not tangled.
Old 09-23-2006
Sabreman's Avatar
Sabreman will become famous soon enough
For about 20 years, each fall we've pulled all our running rigging and replaced it with 1/8" line for winter storage. For many years, we washed the lines in the washer using laundry detergent. The down side is that the lines become very tangled and sometimes yacht brade developes a pull on the cover which can not be fixed. We not put the lines in our jacuzzi with detergent and turn on the jets! Lots of bubbles develop which we throw at each other. The lines come clean and smell nice. Using this technique, our lines last an average of 10-12 years because they're out of service for 5-6 mos a year. Lines that spend most of their lives hidden in the mast are turned end for end at about 6 years.
Old 09-23-2006
tommyt is on a distinguished road
The mesh bag will work, but so will a zipped or tied pillow cover as well. Put up to 50' of line in a pillow cover and wash with detergent and fabric softner. Hang to dry. Works great and no major tangles at all.
Old 09-23-2006
bbistis's Avatar
First time I jumped into one of these infochats... pretty cool. Thx.
Old 09-23-2006
SailorMitch's Avatar
Senior Moment
SailorMitch will become famous soon enough
Use mesh bags (can buy them at Wal-Mart, etc. for not much money) to hold the sheets -- leave the line loose in the bags. I wash mine every winter using regular detergent and cold water. It helps them last longer IMHO. Keeps them supple if nothing else. I also put old towels or rags in with them to balance the load during spin cycles. Loosely coil and hang to dry and you're all set.
Oh yeah, I use our home washer, but only when the Admiral is out of the house.
SailorMitch
Sailing winged keels since 1989.
1.20.09 Bush's last day the end of an error !! Hopefully we still have a constitution and economy left by then.
"Compassion and tolerance are not a sign of weakness, but a sign of strength." The Dalai Lama
good planets are hard to find-- a song by steve forbert
I have but one lamp by which my feet are guided, and that is the lamp of experience. I know no way of judging the future but by the past.-- Patrick Henry.
Old 09-23-2006
hellosailor's Avatar
Besides the bag or pillowcase?
Use the FRONT-LOADER at the laundromat, and use gentle cycle with whatever options for soaks, etc. you have. There's nothing wrong with coiling & tying or securing the line before you wash it, the water will still get all the way through.
Washing is a good thing, because dirt and salt crystals (from salt water) are just as abrasive as sand, and they cut the lines apart from the inside out.
Double Spinn Sheets davidk Racing 25 03-07-2007 02:22 PM
spinnaker sheets doctorroberth Gear & Maintenance 2 12-04-2001 05:02 PM
Spec Book or sheets upacreek Gear & Maintenance 0 05-02-2001 05:33 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
