Varnish vs TSP - SailNet Community
Blogs
Old 09-25-2006
Azura's Avatar
Azura is on a distinguished road
Varnish vs TSP
My boat is presently dry and unvarnished. The decks are fiberglass in need of paint. The paint manufacturer says I have to wash the decks with TSP (TriSodium Phosphate) prior to painting. My teak trim is sanded bare now. Do I wash everything now and risk raising the wood grain or do I put several coats of varnish on the wood and hope that the TSP doesn't mess up the varnish?
Old 09-25-2006
AirborneJarhead is on a distinguished road
I know I'm probably stating the obvious, but shouldn't the teak trim be removed? I ask because I'm about to paint my deck and cabin trunk and anticipated having to remove hardware and teak. If I can do it without removing the stuff, I'm all ears!
Old 09-25-2006
JohnPen is on a distinguished road
I removed all my teak trim a year ago, sanded, 8 coats of varnish, reinstalled. looks great! Only real challenge was finding a decent bedding compound that would work (3M 101) Polysulfide.
You will thank yourself for removing it and doing it the proper way.
Old 09-27-2006
Azura's Avatar
The small teak items, all winches, and hatches have been removed. The boat still has teak coaming pieces and a teak cap rail. I am not removing those. I'm leaning toward varnish first.
Old 09-27-2006
Seems to me you could either a) mask off all the teak trim with a poly sheet and waterproof tape, wash your deck and paint it or b) varnish all your teak, let it cure, then repeat (a) above.
Old 09-28-2006
Parley is on a distinguished road
I would be concerned about the tsp removing the "sheen" of any varnish that has been layed down. I would apply the first couple coats of varnish (to somewhat seal the teak), mask it off, complete the deck painting, remove teak masking, mask deck around teak, and complete the teak varnishing. All will be good.
Old 09-28-2006
ehmanta's Avatar
Sailing Junkie
ehmanta is on a distinguished road
I would neveruse trisodium phosphate on or near the water due to environmental hazards (harmful to fish etc). They due make a substitute for it however that is phosphate free. good luck.
Old 09-29-2006
hellosailor's Avatar
I'd call 3M. For two reasons: they make all sorts of tapes, and I second the concept of using a waterproof tape and poly, since you WILL have to mask off the teak anyway. In fact, 3M makes a "blue" masking tape with poly attached to it, so you can do the masking in one shot. (Any hardware/paint store.) But they also make more durable tapes. If the tape will be left in place exposed to sunlight for more than a week, you want a more durable tape so the gum doesn't transfer to the wood.
3M also makes a full line of painting and refinishing supplies including "prep/solve" a solvent that removes all waxes and polishes from fiberglass to prep it before painting. Yes, you can use that instead of TSP, which is banned in many states anyhow. It will cost more--but like most solvents, it shouldn't raise the grain of the teak. You could probably clean the deck with prep solv and clean rags, THEN mask the teak after it had evaporated off. (Should also clean the teak well enough to get the tape stuck down nice and tight after.)
****'n'span used to be mainly TSP, the ban made then switch formulas AFAIK.
Old 09-30-2006
It depends on what kind of paint you'll be using. If you're going with a two-part linear polyurethane paint, I would remove all the hardware and wood. The paint really works much better if it is applied to the entire deck, rather than applied to the deck around things like deck hardware, and will last much longer. It is a lot more work, but that's what I would do.
I don't think that TSP will harm varnish as a general rule...but it isn't very friendly to the environment.
bristol coating instead of varnish jklewissf Gear & Maintenance 4 03-19-2010 09:51 AM
Help, please with varnish colour... FrankLanger Gear & Maintenance 11 09-08-2006 12:02 PM
Sikkens marine varnish obiec Gear & Maintenance 3 05-13-2003 03:55 PM
best exterior varnish obiec Gear & Maintenance 5 02-06-2003 04:23 AM
Varnish remains off Deck jb Gear & Maintenance 3 04-28-2002 09:38 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
