is there a non impeller speed-log? - Page 2 - SailNet Community
post #11 of 21 Old 01-17-2007
MiddleBaySailor
OOPS! Speed=distance/time
f123olly is offline
post #12 of 21 Old 01-17-2007
MiddleBaySailor
OOPS! Speed = distance/time
f123olly is offline
post #13 of 21 Old 01-17-2007
Ronbye's Avatar
Seafarer used to make one. It was originally installed on my boat before I bought it. I have just sent to one of our forum members both the Seafarer depth sounder and speedlog units.
Ronbye is offline
post #14 of 21 Old 01-18-2007
deckhanddave's Avatar
I wonder if this could be a function of a more advanced depth finder? I haven't done the research but I bet there is something like that out there in the fish finder/ depth finder market. Of course it would be limited by the depth of the water... once the bottom is past it's max range...
deckhanddave is offline
post #15 of 21 Old 01-18-2007
trantor12020's Avatar
Check out Airmar at www.airmar.com They have some speed sensors that uses ultrasonic (I think). Search for CS4500. It looks like Airmar made transducers (sensors) for use on many brands of instruments eg. Raymarine, Navman, Simrad etc....
Interestingly, just early this week, I ordered a replacement ST40 Speed transducer and found Airmar transducer in the Raymarine packaging. I called the dealer to verify and was told its indeed correct.
trantor12020 is offline
post #16 of 21 Old 01-18-2007
PR Sailor
velero's Avatar
What was the cost
of the Airmar Sensor that you got from Raymarine?
velero is offline
post #17 of 21 Old 01-18-2007
US$100 for the paddle wheel transducer. I think its too expensive. I already paid for a replacement Display unit earlier then found out that the transducer is also faulty. bummer.
post #18 of 21 Old 01-19-2007
Owner, Green Bay Packers
Other than dual transducer units for use in shallow water the only non-wheel log I know of is the pitot tube type. I know of none suitable for boat mounting, and they are all subject to damage due to their protuding beneath the hull.
sailaway21 is offline
post #19 of 21 Old 01-20-2007
Valiente's Avatar
I have a very old (late '80s) cathode ray tube depthfinder called a Marinetek Video Sounder.
I have NO CLUE how it works, but it involves a squared-off hull projection with a glass window (I dislike this on general principles...). However, it did work last season and did give a decent and fairly vivid idea of the bottom, but it sucked at depths over 40 feet, and eventually grew a coat of algae that meant it recorded all depths as 3.2 feet...I have to clean it this winter.
Did I mention that the Video Sounder (when scraped clean) gives a pretty accurate speed under way? Over about 1.5 knots, that is. I don't have an impeller thru-hull, just this old thing and a 1990s Raymarine chartplotter that tells me when I'm doing over 2 knots.
Valiente is offline
post #20 of 21 Old 01-21-2007
http://www.chicagomarineelectronics.com/nkeSensors.htm
Here's one place with a price list for the NKE electronics.
seabreeze_97 is offline
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 03:42 PM
Atomic 4 is 4 lovers agent4change Gear & Maintenance 11 08-07-2011 06:14 PM
Hull speed and wide sterns Jeff_H Boat Review and Purchase Forum 24 11-22-2006 12:58 AM
Hull Speed Sailormon6 General Discussion (sailing related) 11 08-03-2002 09:16 AM
ideal wind speed? brucemcald Learning to Sail 9 07-21-2001 06:30 PM
