Yamaha 15hp vs. 20hp - SailNet Community
 1Likes
post #1 of 12 Old 01-01-2016 Thread Starter
If you choose the portable 15hp and 20hp next to each other on Yamaha's website (scroll down to see comparisons), they appear to be the exact same motor, other than the horsepower. Same displacement, size, weight, etc. Anyone know what that's all about?
Comparisons | Yamaha Outboards
Jeanneau 54DS
Minnewaska is offline
post #2 of 12 Old 01-01-2016
Re: Yamaha 15hp vs. 20hp
Very typical with a number of OB mfgs to have 2-3 different HP motors that appear to be the same motor. From what I understand, it's usually a difference in carboration that makes up the difference in HP rating.
chuck53 is offline
post #3 of 12 Old 01-01-2016
FSMike's Avatar
Originally Posted by Minnewaska View Post
If you choose the portable 15hp and 20hp ----
Portable?
Anyway, probably different carburetors.
Sail Fast Live Slow
36' Solaris Sunstar catamaran
FSMike is offline
post #4 of 12 Old 01-02-2016
4KSB driver.
SHNOOL's Avatar
Dock
Yeah this is pretty common...
Merc 2.5 and 3.5
Merc 4, 5, and 6
Merc 8 and 9.9
etc.
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is offline
post #5 of 12 Old 01-02-2016 Thread Starter
Originally Posted by FSMike View Post
Portable?
Yea, portable, funny at over 100lbs. Their term.
There is roughly a $400 price difference between the 15hp and 20hp. No way the carb actually costs more, so the profit margin on the 20, must just be that much higher.
Makes one wonder if the 15hp carb can be modified into the 20hp carb, not that I think I'll go through the trouble.
This curiosity started, as I was contemplating putting a 15hp on the new dink, to save weight and cost. With no real savings in either, it would seem silly not to have the extra hp from the same motor, when you may wish you had it.
Jeanneau 54DS
post #6 of 12 Old 01-02-2016
This is always worth checking when you buy a dingy motor. Yamaha I think the 4 and 6 HP are the same weight, as is the 8 and 9.9 HP. I ended up with a 6, same reasoning.
capecodda is offline
post #7 of 12 Old 01-02-2016
MarkofSeaLife's Avatar
Dock
Yes it can. Voids warranty, of course, so its silly to do it to a new motor.
I was going to do it to my Merc 9.9 to make it a 15. Guess how much the new carb costs?
Go on, guess!
It is... (are you sure you have guessed yet?)
$400.
Sux, donnit?
Minnewaska likes this.
MarkofSeaLife is offline
post #8 of 12 Old 01-02-2016 Thread Starter
Originally Posted by MarkofSeaLife View Post
......Sux, donnit?
I guessed $500, so there would be the illusion of value.
Jeanneau 54DS
post #9 of 12 Old 01-02-2016
HANUMAN
RobGallagher's Avatar
This is one of those lessons learned after I purchased a like new 6HP electric start merc. (from my 90+ yr old grandfather who put it on his credit card thinking he was gonna start clamming again but told not to pull start a motor because of his new pacemaker). I could not believe how heavy it was compared to my 4HP so I started doing the research.
I took it back to the Merc dealer and traded it in for a 5HP that was MUCH lighter.
So, IMHO, always buy the highest horsepower rating in the weight category.
I also always wondered about carb, and if you even need a bigger carb, or just new jets or other bits?
HANUMAN
'88 C&C 30 MKII
NOANK, CT
RobGallagher is offline
post #10 of 12 Old 01-02-2016
Fortuitous
chip's Avatar
You sure it wasn't an 8? The Merc 4, 5, and 6 are all the same weight (except for the slight difference that come with different shaft lengths.)
Mercuries, Nissans, and recent Evenrudes in that size range are all made by Tohatsu, and the 4/5/6 in all of those brands is the same block. The 8/9.9 is the next block up, and the 15/20 after that. As others have said, they just dial back the power for the the lower HP ratings for each block with rev limiting and/or carb changes.
Yamaha does something similar. It's pretty common. It would likely be too expensive to engineer, produce, and carry parts for unique engines for such small changes in HP (in the grand scheme of outboards).
My Boat Log, or "blog" if you will:
chip is online now
WTB: 2cyl diesel 10-20hp 10-john Diesel 2 09-01-2015 11:59 AM
Yamaha 15hp vs Honda 15hp outboard? drakeParagon Outboard 4 03-24-2015 05:55 PM
How to find electrical load of 20HP diesel preservedkillick Electrical Systems 7 07-28-2014 09:29 AM
Evinrude 15hp OB Motor smoking Birdface Gear & Maintenance 27 03-20-2009 06:16 PM
Yanmar (3GM 20hp) Blue Smoke Problem animaashi Gear & Maintenance 3 11-05-2001 06:18 PM
