Solar charger setting - SailNet Community
post #1 of 1 Old 2 Weeks Ago Thread Starter
just ducky
I currently have my solar controller set to hold absorption for 1 hour at 14.6V. I wonder if there would any danger or plus/minus to just set it to 14.4V till it either can not hold due to the sun or till amps get to 0.5% capacity.
These are 6V wet cell so there is a con of needing to check the water level more often. But I bet after a while I learn how often they are going to need water (currently they need water about every 3 months).
Don't blow air up my rear, be useful and blow it at the sails!
Don0190 is offline
Setting up a 24v solar charging system Minnesail Gear & Maintenance 11 08-18-2014 03:54 PM
Solar charger for BlackBerry nomchang Cruising & Liveaboard Forum 7 05-14-2009 11:49 AM
Solar Charger on Woot.com Quickstep192 Gear & Maintenance 6 01-28-2009 04:45 AM
Solar Charger wind_magic Gear & Maintenance 3 07-02-2007 11:05 AM
Solar Charger Control fassje Gear & Maintenance 6 11-05-2006 06:51 PM
