An end of the season confession - Page 2 - SailNet Community
post #11 of 21 Old 10-20-2006
Surfesq's Avatar
What a bunch of gloom and doom!!! You guys want to slow dance together?
Look, it's all about rebirth and planning. Winter is a great time to re-wire the boat, organize the charts, re-varnish the interior, replace the cushions or change out the stove. Its a time for hanging out in the cabin and dreaming of places you want to see. Go on down to the boat, crank up the diesel heater and do some of those things you have ignored while it was nice out.
Quit crying like a bunch of fricking babies and get to work!!
Surfesq is offline
post #12 of 21 Old 10-20-2006
Surfesq's Avatar
Surfesq is offline
post #13 of 21 Old 10-21-2006
purveyor of mischief
sanctuarysam's Avatar
hey surf..i'm having deja vu all over again with you last posts..
i keep my boat in the water year round and will sail anytime as long as the boat isn't covered in ice..(although this point is negotiable)..poly-pro long underwear warm gloves and a hat..hell..it's always sailing weather as far as i'm concerned..
just my $.02 adjusted for inflation
By three methods we may learn wisdom: first, by reflection, which is noblest,second is by imitation, which is easiest,third is by experience, which is the bitterest.
Sam
Sanctuary, Sabre 30 mkIII
sanctuarysam is offline
post #14 of 21 Old 10-21-2006
can't re member
I'm with you Sam! If you're dressed properly, sailing in a snowstorm is pretty cool if a little surreal. Wear gloves though or your knuckles will crack and bleed...not so cool.
yotphix is offline
post #15 of 21 Old 10-31-2006
kjsailingSpring's Avatar
Winter Question
I feel the same blues now that winter is here. I'm on the boat every weekend in the summer and fall and winter depresses the heck out of me. What has helped me was to make out a schedule for one sailing/boat related project each weekend of the winter. I have new lifelines to swage one weekend, jib to repair another, clean my stormsails another and so on... It helps me and then I'm ready for sailing as soon as March rolls around. The written schedule is the key so that you can see the end of winter in sight and feel progress as the weeks tick off.
One question to you hearty winter sailors...I'd love to take my boat out on a warm winter day but I can't cause I've winterized the engine. How do you take your boats out in cold climates yet insure that the harsh days don't freeze the engine? I have an inboard yanmar diesel and I sail out of Atlantic City, NJ. Is there a compromise to winterizing?
kjsailingSpring is offline
post #16 of 21 Old 11-01-2006
Don't know how your boat is winterized but mine is done by putting in two ounces of fuel treatment (Biobor) per 30 gallons of fuel and pouring two gallons of -100 antifreeze directly into the sea strainer with the engine running until it exits the through-hull.
If you go out, the antifreeze is ejected when you start the engine, so all you need to do is replace it when you get back in.
SailinJay is offline
post #17 of 21 Old 11-01-2006
SailinJay-
Pouring antifreeze into the water is probably illegal in most states...YMMV...but I doubt the local water police would approve, and the fines can be both steep and nasty.
sailingdog is offline
post #18 of 21 Old 11-01-2006
Señor Member
TrueBlue's Avatar
SailinJay-
SD,
Most boaters (especially sailors) are sensitive to the environment and use only Propylene Glycol Antifreeze in the raw water sections of their boat's engine. Hopefully you do as well.
I always buy undiluted and mix it 50% with water in a five gallon bucket. A hose is then fed to the sea water strainer, which draws the solution into the engine after starting. As previously mentioned, I also shut down as soon as it's seen exiting from my wet exhaust.
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #19 of 21 Old 11-01-2006
Send a message via MSN to LyleRussell
Want winter to end quickly?? Take up snow skiing. Once hooked like me winter is never long enough. As soon as skiing is done it's time to get the boat ready. House $#!t work, do that in March or December.
LyleRussell is offline
post #20 of 21 Old 11-01-2006
I assumed in my previous post that everyone used the RV/marine non-toxic propylene glycol antifreeze.
Double-ended Ferries, Which end is front? Wdobner General Discussion (sailing related) 14 10-23-2009 09:22 PM
Badger season ends with smooth sailing Sunday (Ludington Daily News) NewsReader News Feeds 0 10-16-2006 04:15 PM
How do I prepare an evinrude 7.5 for the season sailingsundance Gear & Maintenance 2 05-28-2003 10:00 AM
End of season maintenance bjoc2314 Gear & Maintenance 4 10-04-2002 06:10 AM
New England 2001 Season Approaches kim Crew Wanted/Available 0 02-06-2001 04:15 PM
