Traveller - SailNet Community
 2Likes
  • 1 Post By SHNOOL
  • 1 Post By Stu Jackson
post #1 of 8 Old 02-13-2016 Thread Starter
Runshari's Avatar
Traveller
I notice that so many new boats do away with the Traveller and rely on on the main sheet. Is the Traveller really needed?
Shari
First mate runner girl
"Wanderlust"
'99 Beneteau 352
Holland, MI
Runshari is offline
post #2 of 8 Old 02-13-2016
4KSB driver.
SHNOOL's Avatar
Re: Traveller
Nope it's not needed... neither are the sails, boom, mast, or rigging... In fact, you could technically ditch the motor too.. and paddle your way around, but where's the fun in that?
Honestly there are tons of examples of boats without travelers. The extra control it gives you though, is welcomed when attempting to get every last ounce of performance out of your mainsail.
If you spend all your time 60 degrees or better off the wind, then a traveler is almost superfluous.
cb32863 likes this.
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is offline
post #3 of 8 Old 02-13-2016
Stu Jackson's Avatar
Re: Traveller
You could read this and get the answers to WHY
Sail Trim Users Guide
I find it indispensable.
Only one L, too.
Runshari likes this.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #4 of 8 Old 02-13-2016
Daveinet's Avatar
Re: Traveller
It mostly depends on the attachment point for the main sheet on the boom. The wind load against the sail will raise the boom which draws the boom toward center. using a traveler, in light winds, one moves the traveler to windward, to allow the boom to rise easily. In heavy winds, the traveler is moved more toward the center, as the stronger wind will cause the boom to rise. So the trick is, that if your main sheet attachment point results in less leverage downward on the boom, the boom will rise more easily. Put the main sheet in the middle of the boom, and it doesn't take much wind to get the boom to rise. So with a mid-sheet attachment point, the boom rises easily, this allows the vang to have a greater range of adjustment all the way up to very light winds. If the main sheet attachment point is at the end of the boom, that may be OK for heavy winds, but does not work for light winds, as the wind is not strong enough to lift the boom much. This means the vang has doesn't do much.
I will say that moving the attachment point farther forward is not a perfect alternative to a traveler, but it does make the traveler less important. I would also suggest that not having a traveler is going to more tedious to get the sail twist correct for any given condition.
Dave
RL 24 NEW to me April 25th 2014
AFC 17' 2+2 (sold in 2012)
Hobie 14'
Sunfish project boat
Sailing a large boat on a small lake is very tacky.
Daveinet is offline
post #5 of 8 Old 02-14-2016
Re: Traveller
If there's no traveler I'd want a very powerful rigid vang. A good vang that can also provide boom lift can make a traveler somewhat superfluous.... It would have to be as easily adjustable and you'll still lose some trimming options, though.
Good traveler setups are costly - probably the main reason for fewer builders providing them. Both is always better.
Faster is offline
post #6 of 8 Old 02-14-2016
Daveinet's Avatar
Re: Traveller
I assumed the main reason was to avoid cutting the cockpit in two. Cruisers have different priorities
Dave
Hobie 14'
Daveinet is offline
post #7 of 8 Old 02-14-2016
Fog Bank's Avatar
Re: Traveller
My only issue with our traveler is where it is placed. Right at the companionway entrance is a pain.
Fog Bank is offline
post #8 of 8 Old 02-14-2016
roverhi's Avatar
Re: Traveller
Travelers came about before the advent of boom to mast (rigid) vangs. Without a traveller, the boom rises as soon the sheet is eased resulting in poor main sail shape. The traveller allowed you to keep control of the boom through a greater, though still limited, range. Back in the good old days a vang was a tackle the you ran from the boom to a strong point on the deck to give downward pull on the boom. Worked fine but had to be constantly adjusted as sheet/boom position changed. Going to a mid mast traveller gave further range of control but still ultimately limited. With the boom to mast vang, the boom is in a more or less fixed position and the traveller becomes a bit of an anomaly. It makes little difference what the tension on the mainsheet has in relation to the boom and sail shape. Grew up with sailing in the old days and still like to have a traveller as it takes most of the considerable downward force needed on the boom when beating or close reaching, I don't have a rigid vang as I didn't want to give up the storage space on deck wiped out by a rigid traveller. My boom is long and height from deck to boom is short so a rigid vang would be at a very steep angle with correspondingly high loads on the hardware. Just didn't want to risk tearing out the anchor points for the rigid vang which is not an unheard of experience.
roverhi is offline
Vang vs Traveller freddyj Learning to Sail 14 12-04-2015 03:59 PM
What the heck do I do with the traveller? Gregrosine Learning to Sail 9 09-03-2013 02:43 PM
traveller pcleary Gear & Maintenance 19 11-21-2010 07:00 PM
traveller track pcleary SailNet FAQ 4 10-10-2010 01:29 PM
When to use the traveller saurav16 Learning to Sail 18 08-28-2007 05:03 PM
