Help with columbia 28 - SailNet Community
post #1 of 11 Old 10-22-2006 Thread Starter
Has anyone taken a columbia 28 offshore cruising or coastal cruising or know anyone tha thas? any info helps I am planning to do both and would appreciate any advice...
pacifichigh is offline
post #2 of 11 Old 10-22-2006
Go to " Columbia yacht owners association " check in you questions there.
C45JCM is offline
post #3 of 11 Old 10-24-2006
I've done both. What kind of Columbia 28 specific info are you looking for?
lonebull is offline
post #4 of 11 Old 06-14-2007 Thread Starter
columbia help
I have a 1970 columbia 28 Hull # 500 older fin keel 3000# will this kind of boat
hold up on coastal waters have you done it?
post #5 of 11 Old 06-14-2007
SENIOR CHIEF
USCGRET1990's Avatar
It's a tough old boat, just might want to check your keel bolts to make sure they are sound. I had one a few years ago (albeit in a lake) but would have taken it anywhere.
USCGRET1990 is offline
post #6 of 11 Old 06-14-2007 Thread Starter
columbia help
thanks for the advice on the keel bolts...I am working on them. they have no leaks but do have some corrosion.I s this something I can fix without replacing them ...none of them are corroded through yet . also do you know how thick these hulls may be?
post #7 of 11 Old 06-15-2007
The hull on my Columbia Sabre is roughly 5/16 to 3/8" in some places.
Sabre66 is offline
post #8 of 11 Old 06-16-2007 Thread Starter
help with columbia 28
well that seems pretty thin ...is that a common thickness for 28' boats?
and a question about my cored deck , it has some hollow sounding spots on the inside but its seems solid on the outside and around deck hardware...should I be worried?
post #9 of 11 Old 06-16-2007
SENIOR CHIEF
If the nuts on the studs that you can see in that little bilge, are still close to original size your probably ok. What I did, was clean the nuts and area very good. Then put some epoxy in a little plastic cup about 2" deep. Then smush it down over the top of that nut, sealing it for good.
I had a core of the hull that was removed a foot or two from the keel. It was almost an inch thick! Up near the gun'l, probably 3/16 to 1/4 inch.
post #10 of 11 Old 06-16-2007 Thread Starter
Thanks for the advice , thats a bit more reasurring, and I'll try the epoxy, that sounds like a good idea. question on your mast...were your spreaders welded to the mast ..every other columbia i have seen has this , is that safe
connection? And do you know anything about the decks on these girls...mine has some weird spots on the inside ...delamination maybe but the outside deck seems solid ...should I be worried ? Or should I just try to reinforce the deck ? Any suggestions are very appreciated ....thanks
Columbia vs C&C ref_123 Boat Review and Purchase Forum 9 03-20-2003 12:01 PM
Columbia 45 davejean Boat Review and Purchase Forum 0 09-09-2001 08:02 AM
1st Boat a Columbia 26 MkII? sprtlvr Boat Review and Purchase Forum 1 09-05-2001 03:58 AM
Columbia yacht''s Chrysler-Nissan engine madhuri Boat Review and Purchase Forum 1 07-06-2001 01:44 AM
1974 Columbia Mk II TMKane Boat Review and Purchase Forum 2 05-29-2001 01:41 PM
