windvane costs - SailNet Community
 2Likes
post #1 of 11 Old 03-04-2016 Thread Starter
windvane costs
How much would it cost to buy and have installed either a Aries or Monitor wind vane?
aliddell1 is offline
post #2 of 11 Old 03-04-2016
Re: windvane costs
The manufacturer or distributor of each would be happy to tell you, but could really use a bit more info. Size of boat, type of transom, etc.
The basic Monitor runs around $5k. If you need the ability to swing it out of the way of a sugar scoop transom, or want the emergency rudder feature, it runs thousands more.
Jeanneau 54DS
Minnewaska is offline
post #3 of 11 Old 03-04-2016
Kynntana (Freedom 38)
gamayun's Avatar
Re: windvane costs
I bought a used Monitor for $1K. Scanmar can tell you its history (they used different steel over the years) and they can take a look at it to make sure it's in good shape because sometimes the fixes cost more than the new one. They're location was convenient for me, but maybe there are other places near you that would do this. They will sell you the parts you need and can also create a mounting design. If you buy new, Minne has it right. A new M-Rudder as an add on for emergencies is around $2K. I think the gate swing is another $1.5K. Basic set up is $4K.
gamayun is offline
post #4 of 11 Old 03-04-2016
Bristol 45.5 - AiniA
Re: windvane costs
Often you will find the best prices at boat show time. We bought our Monitor at Annapolis and it was quite a bit below list. You can buy a new Aries (I think) but most people buy on the used market. You can install one yourself, it is not too hard to do. Less stressful to do on the hard when the bits you drop can generally be found. We did ours in the water with the inflatable tucked under the transom to catch things trying to escape.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #5 of 11 Old 03-06-2016
roverhi's Avatar
Re: windvane costs
Install the vane yourself. If you are serious about going cruising, you want to get intimately familiar with the most important piece of gear on the boat. For most vanes it's just drilling a few holes, bolting on brackets or the vane, and running the control lines and blocks, if needed. You are in a great place to buy a used vane which will cut the cost considerably. When I had the boat in Alameda, sold the barely used Monitor the boat came with for $1,700 with wheel adapter. Bought an auxiliary rudder WindPilot Pacific Plus vane that helmed me around the Bay and to Hawaii for the same price. Seems like vanes of all different stripes showed up regularly on Craig's List or Latitude 38 classifieds while I was preparing the boat for the passage. Inspect early or heavily used Monitors carefully. There has been some reports of welds cracking after long term serious use.
The manufacturer's websites have the list prices for new gear if you want to go that route. Installation may be easier in the case of the monitor because it's oil derrick construction requires cutting SS tubing to the proper length. WindPilot, Sailomat and others of that type are just a matter of drilling four holes and bolting the gear on if you have a relatively flat surface.
roverhi is offline
post #6 of 11 Old 03-06-2016
Pamlicotraveler's Avatar
Re: windvane costs
I can recommend the Monitor. I have used it for many miles including 2 transatlantics and considered it the most reliable crewmember. They are expensive. Hans Bernwell, the CEO told me his biggest competition for his company is the used Monitors floating around, not another maker. I believe that because they are very well made. Now they are 316 stainless and the welding and bracketing is first rate. There are other good makers of course, but I would prefer the servo-pendulum method.
The cost of a Monitor is about $5,000 and the wheel steering adapter is another $500. I think to have someone install it correctly would take another $1,500. So it's an expensive proposition, but for me it's the best accessory you can have.
"Tell 'em I'm busy. I'm on a sails call."
Pamlicotraveler is offline
post #7 of 11 Old 03-06-2016
Re: windvane costs
I think if you want to go anywhere that requires a vane rather than an electric autopilot you owe it to yourself to do the install. For extended cruising you need to know basically everything about your boat.
MedSailor and ebourg like this.
post #8 of 11 Old 03-08-2016
Re: windvane costs
I bought a second hand aires for 500 dollars and installed it myself for about 100 dollars it needed a really good clean and lube up but she goes great,you will need to really brace any unit you buy up as they put huge forces on your transom no problem on my steel boat,but would want huge backing plates in anything else.
harmonic is offline
post #9 of 11 Old 03-08-2016
Master Mariner
capta's Avatar
Re: windvane costs
If you've got a boat with an outboard rudder, you could probably build a trim tab vane gear for around a grand all inclusive.
facebook.com/svskippingstone
Our Videos;
capta is offline
post #10 of 11 Old 03-08-2016
roverhi's Avatar
Re: windvane costs
Servo Pendulum Vanes like the Aires actually put very little strain on the transom unless you back the boat into an immovable object. The force you have to counter is the effort needed to move the tiller which is minimal in the real world scheme of things. Fender washers are suitable for backing of the fasteners.
Auxiliary Rudder Vanes like the HydroVane, WindPilot Pacific Plus, etc. do put considerable strain on the transom but nothing requiring extensive reinforcement because the vanes rudder is doing the actual steering. On my boat, 6" X 6" X 3/16" fiberglass plates have worked just fine backing the four mounting points of the WPPP.
roverhi is offline
Arch and Windvane. tdw General Discussion (sailing related) 11 02-09-2015 04:08 PM
Aries windvane loup30s Gear & Maintenance 0 01-27-2012 07:12 AM
windvane installation SueDMason Gear & Maintenance 4 04-09-2003 05:37 AM
windvane choices??? staceyneil Cruising & Liveaboard Forum 2 06-25-2002 08:20 PM
windvane Colm1 Gear & Maintenance 0 01-15-2002 04:41 PM
