Re plating chrome dorade vents? - SailNet Community
 1Likes
post #1 of 45 Old 10-28-2006 Thread Starter
T37Chef's Avatar
Question Re plating chrome dorade vents?
I need to re-plate my chrome dorade vents. I looked into a professional and it was costly, I could spend just a little more and replace them with stainless. I’m thinking I could re-plate them myself. How, what, has anyone done this before and were the results worth the effort. Any suggestions would be appreciated?
EDIT: UPDATE ON SERVICE PROVIDED BY AMERICAN PLATING SERVICES IN BALTIMORE MARYLAND, see post 28
jocar105@aol.com likes this.
T37Chef is offline
post #2 of 45 Old 10-28-2006
Gene T's Avatar
I spray painted some once and they came out really nice. Easy and cheap.
Gene T is offline
post #3 of 45 Old 10-28-2006
Re-chroming them isn't really something you can do at home. You might be better off sanding them and then painting them.
sailingdog is offline
post #4 of 45 Old 10-28-2006
tdw
Super Fuzzy Moderator
tdw's Avatar
Originally Posted by T37Chef
I I’m thinking I could re-plate them myself. ?
Chef,
The quality of chrome plate required for marine environment is significantly higher than for non marine. I'm not an expert on the subject but my work involves exterior lighting where we require chrome than can be used on beach houses. If you were to try and do it yourself, if indeed that is possible, it would almost certainly result in pitting and corrosion in a very short time. Either pay the money or paint them.
TDW
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #5 of 45 Old 10-29-2006
Chef, have you checked you Yellow Pages and tried to deal directly with a local "chroming and plating" shop?
Depending on the shape they are in, they will be acid-dipped and polished down to a smooth base layer, then they may need multiple coats of chrome and more polishing along the way. It's not a simple or fast job and there are EPA complications with the chemicals these days too.
If you can find a real chroming shop, and drop yours off to have them done in a batch with other work (instead of scheduling just for you) you may get a better rate. Make sure they understand marine use and the need for really heavy plating.
hellosailor is offline
post #6 of 45 Old 04-26-2008 Thread Starter
T37Chef's Avatar
Alright, I finally took the dorades off since I am sanding and cetoling the dorade boxs...
so does anyone have any recommendations for someone in Maryland, Northern Virginia, or DC?
Shawn
T37Chef is offline
post #7 of 45 Old 04-26-2008
poopdeckpappy's Avatar
Powder coat them, ( or check into it at least ) most PC'ers will have chrome PC, among others, even some that look like SS
And if you PC the outside Chrome or SS, you can then have the thoat PC'ed to match the boat accent
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #8 of 45 Old 04-26-2008
artbyjody's Avatar
What kind of materials can be chrome plated?
-- Jody
S/V "
1983, Barberis Show 38! or
artbyjody is offline
post #9 of 45 Old 04-28-2008
Catalina 38 Avantura
duffer1960's Avatar
The best thing to do is go to your local Harley shop and ask them where the best places are for chrome plating. Bike customizers are chroming various parts all of the time.
Sincerely,
Russ Duff
Catalina 38, Hull #112
"AVANTURA"
Lake Erie
Grosse Ile, Michigan
duffer1960 is offline
post #10 of 45 Old 04-28-2008
I'll second a couple of the suggestions. Powdercoating is relatively inexpensive, durable and there are a myriad of colors. As for chroming, duffer has a good idea to get in touch with you local bike shop. You may be able to piggyback on their next order. One thing though is things can get lost at the platers. I've had friends that have lost entire car bumpers at the platers!
48Dodge is offline
Cowl Vents annfer Gear & Maintenance 2 10-11-2002 03:08 PM
