11-16-2006
Pigslo-
Wrote that when I was tired.. should be two separate things... Easier to reef. Easier to tension as there is less friction in the system than a bolt-rope main.
The easier to reef has nothing to do with the bolt rope... for instance, I have sail ties for the reefing points wrapped around the boom...just waiting for the sail to drop...They're bright orange, so they're easy to see—so I don't try to un-reef with them still attached.
