overheating diesel - Page 2 - SailNet Community
post #11 of 15 Old 11-08-2006
jerryrlitton's Avatar
Cruisingdad said temp guage and I agree, but check out all of the electrical componants. That is obviously where the problem resides since the engine does not produce heat when it is not running. It could be as simple as a bad ground.
Jerry
Part time PADI instructor, part time sailor. Full time having a blast.
S/V TEMPTATION
Islander 44
jerryrlitton is offline
post #12 of 15 Old 11-09-2006
My overheating problem turned out to be not enough solution in the closed side of the cooling system. Make sure that everything is full! Check the tank after each brief running of the engine .
Goodnewsboy is offline
post #13 of 15 Old 11-09-2006
Thanks Courtney.
When the engine isn't running, is the ignition still on? If the ingine is off and the ignition is off, it isn't likely to be an electrical issue w/guage.
Who looks at the temperature guage when the engine is off anyway?
T34C is offline
post #14 of 15 Old 11-09-2006 Thread Starter
Caribbean Surveyor
canadianseamonkey's Avatar
Well thanks to all you guys for the info and suggestions.
Since I live in Ontario Canada and sail in the North Channel of Lake Huron, winter is upon us and the sailboat is on land. I will only be able to check the engine, gauge and wiring in the spring. At least I know that the over heating problem above the hull speed is nothing to lose sleep over. As for the engine over heating while sailing, it never made sense to me either. I'll have to get more info from the previous owner and get back to you. It may be the transmission he's talking about.
canadianseamonkey is offline
post #15 of 15 Old 11-13-2006
To clarify my prior post, I had a problem like yours with a Yanmar 2GM that has a closed cooling system. The previous owner had reported the overheating problem to the broker.
The problem was a failure to completely fill the closed side of the system with coolant. We ultimately had to add increments of coolant over a period of about 1 hour with a short run of the engine in between each shot.
My engine has a hot water heater in the circuit, and I think that is where most of the added coolant went.
I have run the engine up to rated output for extended periods since and there has been no overheating.
fuel consumption gas vs diesel jklewissf Gear & Maintenance 25 05-11-2013 08:28 PM
Diesel vs 4 stroke outboard??? bugged Gear & Maintenance 21 11-28-2010 07:15 PM
gas vs diesel reid5009 Living Aboard 1 02-07-2003 01:43 PM
Working in the Caribbean: diesel repair namaste04 Cruising & Liveaboard Forum 7 12-21-2002 07:02 AM
diesel tachometer diesel MHRitter Gear & Maintenance 1 09-17-2002 12:52 PM
