Changing a shroud - SailNet Community
 2Likes
  • 1 Post By captjcook
  • 1 Post By Stumble
post #1 of 9 Old 04-12-2016 Thread Starter
Master Mariner
capta's Avatar
Changing a shroud
If you were going to change out an after lower on a conventional rig, would you loosen all the lowers while that one was off the boat, or just undo the one you were replacing, leaving the others tight? Maybe 48 hours, no more.
facebook.com/svskippingstone
Our Videos;
capta is offline
post #2 of 9 Old 04-12-2016
roverhi's Avatar
Re: Changing a shroud
Just change out the one without messing with the other shrouds. Be sure when you retighten the shroud the mast stays in column. Siting up the sail track will tell you. If you have a tension gauge can measure the tuning before pulling the shroud and retighten to that same tension after replacing the shroud.
roverhi is offline
post #3 of 9 Old 04-12-2016
I would loosen its mirror before pulling it. I doubt it's strictly required, but on a lower there's no reason not too.
Greg
Stumble is offline
post #4 of 9 Old 04-12-2016
Bristol 45.5 - AiniA
We have done it by just taking off the lower without slacking off the opposite shroud. We could see no change in the mast while we were lowerless.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #5 of 9 Old 04-12-2016
While I don't believe it is "wrong" to leave mirror in tension, I would go with Stumble as it may be easier to tune both lowers upon replacing the one. I would recommend rechecking tension in a month as the new will "stretch" just a bit when first installed. Stretch is a poor term, maybe the lay will tighten, slacking stay would be better.
SHNOOL likes this.
captjcook is offline
post #6 of 9 Old 04-12-2016
Ithe term is constructional stretch. And yes you need to tune it out. Generally it takes about a day to work itself out, unless the shroud is very heavily stressed.
Greg
Stumble is offline
post #7 of 9 Old 04-15-2016
Could one temporarily replace the tension with a halyard?
banjoflyer is offline
post #8 of 9 Old 04-15-2016
Banjo,
Not really. The lowers control lateral bend in the middle of a mast, and on swept back spreaders control the forward-aft bend. A halyard only controls the top of the rig, and perhaps a bit of compression vertically.
But almost all masts can stand just fine with slack or missing lowers. Until you get into multiple spreader rigs and are talking about all of the non-cap shrouds.
banjoflyer likes this.
Greg
Stumble is offline
post #9 of 9 Old 04-19-2016 Thread Starter
Master Mariner
capta's Avatar
Thanks all. Job is done. Just tightened against the Stb fwd lower and all is well. I love it when folks in the West Indies can do a job in a jiffy.
Highly recommend Turbulence, Grenada, Prickly Bay.
Our Videos;
capta is offline
Shroud Attachment FirstCandC Gear & Maintenance 12 10-05-2013 07:50 PM
moisture at one shroud abrahamx Gear & Maintenance 12 06-01-2013 01:15 PM
shroud tention dodgeboatguy Gear & Maintenance 1 06-26-2007 01:37 AM
shroud clamp.. groundhog Gear & Maintenance 7 05-24-2007 01:24 PM
Shroud tension ktucker8 Gear & Maintenance 31 08-29-2006 09:25 PM
