Pilothouse designs - Page 13 - SailNet Community
 2Likes
post #121 of 130 Old 02-04-2008
dutch doors
Valiente, this place has what you're talking about: aluminum water tight dutch companionway doors. www.siamondseaglaze.com
Hope this helps. Bob www.sv-restless.com
steelboat is offline
post #122 of 130 Old 02-04-2008
dutch doors
oops. that should be www.diamondseaglaze.com . go to products, doors, medium duty, dutch. They custom make them; I don't know price. Bob
post #123 of 130 Old 02-05-2008
Valiente's Avatar
Thanks, Bob...that is the general idea, but cut that height in half. Basically, I have a 36" high smoked plexi dropboard in a wooden grooved "frame" throughbolted to the steel pilothouse itself. Above that is an excellent Atkins & Hoyle sliding hatch that is fully "doggable" and is in heavy-duty sliding grooves.
The sliding hatch is padlocked over the dropboard top flange. You either would have to boot in the dropboard or snap off the padlock to gain entry.
The "sill" is about two inches. My aft deck is pretty high...I can't say I've ever have even a splash from a following sea there...but that's in Lake Ontario, where getting pooped is usually a function of not seeing the squall line crawling up your stern.
What I want to get is basically two gasketed aluminum panels, both doggable from the inside and lockable from the outside. The lower panel can be solid, and the upper panel can have either a fixed or an opening ventilation port, maybe 5 x 12 or so, with heavy glass. The idea is that the lower half, when dogged, makes for a "bridge deck" of 20 inches, while the upper part can be latched open, with the dogged hatch keeping all but horizontal rain out. This will allow ventilation and communication in moderately heavy weather, but also will allow a quick way to seal the pilothouse far better than present. Even fully shut, in a capsize, we would take on water. A well made gasketed and horizontally split door would lessen water ingress significantly, and would make the boat a more daunting target for burglars in port.
In the picture above, you can see the saloon companionway. I also want the ability to close that with gasketed aluminum panels, as well as a similar "downstairs" to the aft cabin. The pilothouse has internal scuppers, believe it or not, so that if I gasket the engine room hatch, and shut those doors, I could take about a foot of sea water in the pilothouse itself before the electrics suffered...
Thank you for the link. You've given me something to think about.
Valiente is offline
post #124 of 130 Old 03-16-2008
Got to love that 'true blue' nauticat pilothouse. No where to go, nothing to do?..You can always just sit around and admire the interior. A real 'pilothouse' fan.
siberian is offline
post #125 of 130 Old 03-17-2008
Siberian-
Valiente's boat is a steel beastie, not a Nauticat, although it does share some similarity in lines with the Nauticat.
sailingdog is offline
post #126 of 130 Old 03-17-2008
christyleigh's Avatar
Originally Posted by siberian View Post
Got to love that 'true blue' nauticat pilothouse. No where to go, nothing to do?..You can always just sit around and admire the interior. A real pilothouse fan.
Yup...... I do it for hours on end .........
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
christyleigh is offline
post #127 of 130 Old 03-17-2008
Señor Member
TrueBlue's Avatar
Thanks siberian,
With my wanderlust and our beautiful sailing grounds, there were very few times when there was "nowhere to go, nothing to do". But, I did admire the pilothouse interior during the past 4 years or ownership - whenever weather conditions made it unpleasant to be outside.
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #128 of 130 Old 03-17-2008
Valiente's Avatar
I like leaning on the "daybed" in the pilothouse and listening to the rain while reading. I like the play of light better there than down in the arguably more comfortable saloon. I guess it's the same as liking a treehouse as a kid!
Valiente is offline
post #129 of 130 Old 10-20-2008
PH Motor Sailors
You should look at a Schucker 40 if you want a great one.
atrometer is offline
post #130 of 130 Old 08-20-2009
Tashiba 31 Pilot House
Originally Posted by jzeke16 View Post
I wasn't able to view the web page that you posted. But since these boats are extremely rare, I think I bought that particular boat. If anyone would like to know more about it, post a note.
I have read your post about buying a Tashiba 31 Pilothouse and have a couple of questions, if you are willing to answer them. Currently I have a Southern Cross 28 which I have restored extensively and which I like. I have it set up for single handing with all lines led aft, a stack pack main and roller furling on genoa and club footed jib.
But now that I have a grandson and want to eventually cruise the Gulf of Maine with him I am looking for something just a bit bigger, especially with broader decks and better accommodations below. I want to stay with a cutter and a boat I can easily single hand. I am 65 and not getting younger. The Tashiba 31 caught my eye, especially the pilothouse version, which I gather is rare. I have a friend who has a larger Tashiba, a 40 I think, that he likes.
Any comments you have or information on these boats would be much appreciated. Do you have any pictures of your boat that you would be willing to share?
Maina is offline
Monterey Clipper 36'' Pilothouse aurorahs General Discussion (sailing related) 2 06-29-2010 07:41 PM
Lee Creekmore - any info on his designs Myblueheaven Boat Review and Purchase Forum 4 11-22-2008 12:09 PM
Hans Christian 44 Pilothouse kaniksu Boat Review and Purchase Forum 4 05-03-2008 01:23 AM
Cruising FAQ''s seerose Cruising & Liveaboard Forum 10 12-27-2007 03:59 PM
Leading Lines Aft\ pilothouse jimthom Gear & Maintenance 5 12-23-2007 02:06 PM
