On many modern boats, the liner constitutes an important structural element, and may provide a majority of the rigidity for the hull. The only way you can really find this out is to talk to either the manufacturer (best) or talk to a marine architect (not as good).
On many boats, the use of an interior pan liner has allowed them to not add as much in the way of stringers and other hull reinforcement, yet get effectively the same rigidity for a much lower cost.
Removing the hull liner from just one side may render that side significantly weaker and less rigid than the other side of the boat and allow the boat to torque or twist in ways that it is not designed to.
If you're new to the Sailnet Forums... please read this POST.
