How Do I Use Jib Fairleads? - SailNet Community
post #1 of 4 Old 11-12-2006 Thread Starter
Kacper's Avatar
Hey Guys,
I've basically been intuiting the adjustments of fairleads...
Can you tell me how and when to properly adjust the jib Fairleads for best sail shape?
My guess is you move them closer to the bow on a run and reaching, and towards the stern when you are closehauled.
Kacper
Kacper is offline
post #2 of 4 Old 11-12-2006
moderate?
camaraderie's Avatar
With your jib fully unfurled, the line from the fairlead to the clew if extended in an imaginary line should form a right angle with the luff of the sail.
camaraderie is offline
post #3 of 4 Old 11-12-2006
Thanks Courtney.
Moving the fairlead aft from that position will flatten the belly of the sail and depower it when the wind speed increases. Conversely, moving the leads forward from that position adds belly to the sail when wind speed drops.
All that being said, start w/ Camarads' example and you can experiment later.
T34C is offline
post #4 of 4 Old 11-12-2006
ASA and PSIA Instructor
As background to Camaradie's statement, the objective of setting the lead is to see that the luff of the jib has a consistent angle to the wind, top to bottom. This esnures the entire sail is working effectively. Basically for a small jib you move the lead forward, for a larger jib, aft.
You test for proper lead setting by slowly luffing towards the wind. If the leeward upper telltails (you need a set of tell tails at the top , middle and bottom of the luff...) lift or break first, you need to move the lead forward. If the lower break first, move the lead aft. You have the correct lead location when all the luff telltails break simultantously. See http://www.ukhalsey.com/LearningCent...clopedia5b.asp for a more thorough explanation.
Also note that when you are not closehauled, maintaining an even luff can reguire moving the lead out to the rail and forward, usually accomplished by a using a short sheet and a block on the toerail. Same rule as above for determining the jib lead location.
sailingfool is offline
Adding jib sail mikeact41 Learning to Sail 5 08-16-2008 10:36 AM
Attaching Sheet to Jib wigwam Learning to Sail 10 10-04-2003 05:29 AM
dousing a hanked jib terryny Seamanship & Navigation 17 01-16-2003 05:19 AM
Jib and Main Halyard Trouble siem Gear & Maintenance 1 07-16-2001 10:08 AM
need to raise the Jib. glowworm Gear & Maintenance 4 04-10-2001 11:46 AM
