I believe most Ham operators can operate on the SSB frequencies legally, or at least monitor them. You may want to setup a schedule with the ham operator for him to monitor SSB frequencies for communications from you.
He can monitor SSB frequencies and you can listen on Ham frequencies... you just can't transmit on them...and it may not be necessary to do so.
Ham
SSB and marine
SSB are different frequencies and to use them you must be licensed as indicated above. The Ham can not use the marine
SSB unless he has a station and operators license for marine
SSB which most do not have unless they are involved in actual sailing.
Also while you and anyone can listen in on Ham frequecies... a Ham can Not broadcast to you... that is illegal. Hams are required to be in direct communications with someone and may not broadcast in the blind.
I recently completed the first part of Amateur Licensing necessary to use the Ham frequencies. I'll be taking the General test in the next few months to get the HF privileges necessary for long haul
radio communications. I'll also have both a ships
radio license and a marine
radio operators license which as simply filling out the necessary forms and payment of fees, no test required for the marine
radio stuff.
Several
radios are available that will function on both the Amateur and Marine bands. You must still be licensed to use each of them even if your
radio is capable.
For more info on Amateur
Radio you can go to
www.arrl.org
I agree that it is probably a very good idea to have a cruising sailor with a license for both Marine and Amature
radio services onboard... it adds a safety factor and some fun.
