Nautical Trivia - Page 20 - SailNet Community
post #191 of 195 Old 12-20-2006
Owner, Green Bay Packers
What were you doing? Sitting on the send key? What's the significance of that, my porcine friend?
sailaway21 is offline
post #192 of 195 Old 12-20-2006
tdw
Super Fuzzy Moderator
tdw's Avatar
Originally Posted by sailaway21
Yes indeed, otherwise known as quadrantal correctors. And they correct the magnetic compass for the horizontally placed soft iron in the vessel-as previously stated.
Here's an easy one. What time is noon?
Aye but is it better to polish the quadrantal correctors ? I think not !
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #193 of 195 Old 12-20-2006
Quadrantal correctors are made of soft iron and, as such, do not polish up too well. They are usually painted black, although I've seen them painted red and green in an attempt to achieve a "yachty" look. Always wondered about the capabilities of those who did that; perhaps they should carry it further and paint the port side deck red and starboard green to keep themselves straight! Polishing spheres in general takes an experienced touch; one not found in the average ordinary seaman. Most deep sea crews find the job onerous and prefer some type of shore gang to be employed. While expensive, these laborers can be found in most deep water ports but do display a wide range of proficiency. As in most areas maritime, if you find an individual with the requisite skill, and the work ethic to acheive a superb outcome, it is best to always employ that same individual. For years Olongapo city was renowned for this trade and many experienced seamen would have their sphere work done nowhere else. Weather and cargo requirements sometimes required employing others will less skill, although the results were, surprisingly, much the same. When spheres acheive a brass, or brass-like state, it has been found that a vigorous rubbing by virtually anyone at hand is sufficient to polish them enough until the job can be done properly by a competent professional.
post #194 of 195 Old 01-15-2007
Originally Posted by Giulietta
St elmo's fire is a rapid electrostatic electroluminiscent discharge caused by the ionization of the air in the vicinity of an small metalical object, normally above ground level.
Is this phenomenon also responsible for the "green flash?"
~Chazz
"Bread is the staff of life; rum is life itself."
lamb0174 is offline
post #195 of 195 Old 01-15-2007
If you are refering to the one seen on sunset, no.
That one is a light refraction, of the sun's light thru the atmosphere. Like the mirror image on a hot road.
Giulietta is offline
Nautical News @ Bostonboating.com NewsReader Mass Bay Sailors 0 10-24-2006 09:15 AM
Nautical News @ Bostonboating.com / Local news brought to you by / NewsReader Mass Bay Sailors 0 10-18-2006 07:15 PM
Nautical News @ Bostonboating.com NewsReader Mass Bay Sailors 0 06-08-2006 12:15 AM
Light Lists, Lighthouses, and Visible Ranges Jim Sexton Seamanship Articles 0 06-19-2003 08:00 PM
Light Lists, Lighthouses, and Visible Ranges Jim Sexton Her Sailnet Articles 0 06-19-2003 08:00 PM
