Mounting a Foghorn/Hailer - SailNet Community
 1Likes
  • 1 Post By zeehag
post #1 of 10 Old 07-15-2016 Thread Starter
Yamsailor
Yamsailor's Avatar
Hi All,
Where do you think the is the best place to mount a loud hailer for purposes of automatic sound/fog signals?
Opinions appreciated.
Thanks
There isn't a device on this world that can measure the indifference I have for that statement.
Yamsailor is offline
post #2 of 10 Old 07-15-2016
Re: Mounting a Foghorn/Hailer
I'd say it depends on the boat model and the free space you have on yours
fred1diver is offline
post #3 of 10 Old 07-15-2016
Mermaid Hunter
SVAuspicious's Avatar
The best places in my opinion are under a spreader or on the front of the mast. The latter makes most sense if you have a mast-mounted radar and can mount the hailer below the radar.
For the spreader your best bet is to use a contour gauge to get the shape and cut a clamp from Starboard or similar to mount the hailer to.
Pulling the wires will be the hardest part.
SVAuspicious is offline
post #4 of 10 Old 07-15-2016
SFBay Sailor
nhsail's Avatar
Dock
Put it under your radar, on a leveling mount, on your Mizzen or radar pole if you are under privileged in masts.
nhsail is offline
post #5 of 10 Old 07-15-2016
Catalina 400 MKII
Scotty C-M's Avatar
I agree with SVAuspisious about the placement on the mast. However, on my boat, I placed it on the radar pole at the stern. Yes, it is right on top of me, but the sound kind of goes over me, and it's OK. Why did I put it there? I took the lazy path. It was so easy to install at that location that I just went for it. It's worked out OK for me.
Scotty C-M is offline
post #6 of 10 Old 07-15-2016
I mounted mine to the radar bracket
xort is offline
post #7 of 10 Old 07-16-2016
Cruiser
wrwakefield's Avatar
Since hailers can also be listeners, I always mount high and forward of my outside steering position. [Main or mizzen mast on a sailboat, and under a RADAR platform affords some protection.]
This placement spares you the bulk of the volume if you are outside while it is broadcasting.
And since a hailer can also be used as a microphone to listen [very handy for listening for other boat/shore sounds in fog, two-way communications with bow crew when yelling doesn't work (e.g., high winds), etc...] that location reduces the chances of picking up your own engine noise, etc. when in listening mode.
Cheers!
Bill
wrwakefield is offline
post #8 of 10 Old 07-17-2016
snake charmer, cat herder
zeehag's Avatar
back in the day when duct tape had cloth base, the hailer/pa on my formosa was allegedly installed by the po of this boat-- under stbd spreader , to see if it was a good place. ok so he never got around to changing duct tape for screws, and it was successful from 2004-2010, when it came crashing down when the last thread broke....
seemed to be successful, as nothing was affected by that placement until gravity got it.
CVAT likes this.
formosa 41, cruising tropics
zeehag is offline
post #9 of 10 Old 07-18-2016
I mounted mine under the radar dome on front the mast
Liveaboard on a 1980 36' Hunter
alctel is offline
post #10 of 10 Old 07-19-2016
Barquito
Barquito's Avatar
Because sailboats move at such lower speeds than other boats on the water, is there much of a concern that fog horns are only directed forward? (ie: you are almost as likely to be run over from the rear as from the front)
Valiant 32
Barquito is offline
Mounting new, to me, winches... FloridaBoy Gear & Maintenance 18 03-24-2015 09:40 PM
Loud hailer/foghorn/PA? Dfok General Discussion (sailing related) 20 01-23-2015 07:24 AM
Mounting a Nanostation 2 Snboard976 Gear & Maintenance 0 09-21-2009 12:01 AM
mounting a compass... groundhog Gear & Maintenance 12 10-03-2006 11:58 AM
loud hailer on new catalina 440 knothead Gear & Maintenance 2 04-27-2006 12:00 PM
