CO detector caused concern - SailNet Community
 3Likes
post #1 of 15 Old 09-01-2016 Thread Starter
formerly: flyingwelshman
Saltwater Taffy's Avatar
A couple of weeks ago I arrived back at my boat after an evening in town.
An irritating chirping was emanating from my cabin - could be heard from the parking lot.
My CO detector was going off. I opened all my hatches and reset the detector.
I was confused about what might have set off the alarm as I understand that carbon monoxide is produced by combustion. I had not been running the engine, cooking, using my paraffin lamp or doing anything that I thought should produce CO.
About half an hour later the alarm went off again. This led me to believe that there was a real issue.
I went over all my electronics, wiring etc. to ensure nothing was shorting out. Everything seemed fine.
The only thing that was going on that was not usual was that my battery charger was working hard to charge my batteries up from dead flat. This was a result of a switch being switched off inadvertently and the batteries being drained by the fridge.
I looked on-line to see if I could find a relationship between battery charging and carbon monoxide.
It turns out that there is a link. The batteries (it seems to be the 6-volt golf-cart batteries are the most affected) off-gas hydrogen at high levels when being charged. Although hydrogen isn't toxic it is recognized as CO by many CO detectors (at 10% of it's actual level).
Once the batteries were fully charged the CO detector did not activate.
I found information on this topic here: The Unexpected Golf Cart Hazard
seabeau likes this.
Formerly "flyingwelshman".
Saltwater Taffy is offline
post #2 of 15 Old 09-01-2016
travlin-easy's Avatar
Re: CO detector caused concern
My CO detector is essentially an explosive gas detector, therefore, all explosive gasses will set it off. Battery acid fumes are explosive.
Gary
baywater and seabeau like this.
travlin-easy is offline
post #3 of 15 Old 09-01-2016 Thread Starter
Gary
It is specifically the hydrogen that activates the CO detectors. Although not toxic, hydrogen is very explosive. The CO detectors recognize H as CO at about 10% of its actual level i.e. 500 ppm H will appear as 50 ppm CO.
The flammabilty of CO - when mixed with oxygen and other gasses - is at a much higher level than its toxicity i.e. you will die from CO toxicity long before it blows you up.
post #4 of 15 Old 09-01-2016
No doubt about that. When I worked in medicine, we had several individuals brought into the Shock Trauma Unit of the University of Maryland Hospital whom had CO poisoning from relatively low levels. We managed to save 99 percent of them by placing them in a hyperbaric oxygen chamber breathing 100 percent O2 at 3 atmospheres pressure. It was amazing at how well that worked.
Gary
post #5 of 15 Old 09-01-2016
Cruising at a snail pace
300 ppm of hydrogen gas in the volume of a boat seems like a lot of gas from a battery. How fast do you have to charge a battery to boil it that hard?
Don't blow air up my rear, be useful and blow it at the sails!
Don0190 is offline
post #6 of 15 Old 09-01-2016 Thread Starter
Dammit Don, I'm a cook not a physicist!
I relied on my Xantrex TRUECHARGE 2 40Amp Battery Charger to regulate the charge.
(It took about 12 hours to bring the batteries up from dead flat to full.)
post #7 of 15 Old 09-01-2016
Any idea what the voltage and amps being supplied to the batteries were? You don't have some automatic equalize feature going on that could have occurred early in the charge cycle do you?
Don0190 is offline
post #8 of 15 Old 09-01-2016
it really doesn't take a lot of amps to boil those batteries, and keep in mind that they bubble a bit when being discharged as well - not a big deal.
If you know your batteries are going to take a hot charge, it's a good idea to adequately vent the cabin with either a solar fan or shore powered fan during charging. I have a solar powered fan in the ceiling of the head, but it is still not sufficient to completely vent the entire cabin while charging the batteries at just 15 amps, which sometimes triggers the alarm. Consequently, I installed a computer fan in the battery compartment that exhausts the hydrogen gasses out of the boat via the engine compartment exhaust system hose. That fan only draws .04 amps, therefore, I let it run all the time.
When I'm not connected to shore power, my 100-watt solar panel keeps my house batteries and start battery fully charged, and still has plenty left over to run the fridge during the day.
All the best,
Gary
post #9 of 15 Old 09-01-2016
Yeah but boil them some much that the cabin gets to 300 ppm hydrogen, to me that's "impressive".
When I was in the Navy we had a massive battery and we discharged/charged the crap out of it lots of times. Yet were didn't set off the detector IN THE BATTERY ROOM let alone the boat.
Don0190 is offline
post #10 of 15 Old 09-01-2016 Thread Starter
All the best,
Gary
I have 2 x 100 watt panels that provide power when unplugged. I was advised to disconnect the solar panels when the battery charger is on. I had switched off the panels and then, inadvertently switched off the AC main which allows shore power to the charger. I was off the boat for 3 days and the the batteries drained.
I'm pretty sure that the solar panels would stay ahead of the fridge, but the forecast was for overcast/rain for the time I was at the dock so I thought it best to plug in.
What caused this? FarCry Gear & Maintenance 14 10-15-2008 01:02 PM
To Whom It Might Concern USCGRET1990 General Discussion (sailing related) 34 07-28-2008 06:16 PM
