Features & Specifications
Enjoy a soothing spa experience anywhere, anytime with the Spa-2-Go portable inflatable spa. This ingenious hot tub is equipped with an exclusive micro air-jet system for relaxing massaging action. Spa-2-Go offers a full 250 gallon capacity,
seats four people and requires no installation.
Comfort Line Products Spa-2-Go: - Portable, inflatable spa
- Seats four adults
- Simple and fast to set up
- Inflates using spa's motor
- Goes anywhere
- Plugs into standard 120v household outlet
- No special plumbing or wiring needed
- Digital temperature control
- Micro air-jets provide relaxing massage
- 1000-watt heater
- Tough K80 vinyl
- 250 gallon capacity
- Outside diameter 82"
- Inner diameter 58"
- Height: 28"
- Filtration system
- Insulair thermal cover included
- One-Year limited warranty
- Model #stg1
- Online only
If I understand your question correctly, you want this to be "
off your stern" - or in water? This portable unit is designed to be on solid ground - not floating off your boat's stern. Even if your invertor is capable of handling the 120v AC, 1000w loads, I doubt the heater &
pump motor is designed to be submersible.
If what you envision is to have it in on deck, or in your cockpit . . . I'll just leave that to other's to comment on.
