Favorite meals while sailing... - Page 15 - SailNet Community
 72Likes
post #141 of 190 Old 07-30-2012
Mermaid Hunter
SVAuspicious's Avatar
Re: Favorite meals while sailing...
We are not talking fine dining here, we are talking about getting a hot meal into you quickly and simply.
Sailing doesn't have to be camping. You can eat well underway.
This thread began life as 'favourite meals while sailing' not favourite haute cuisine, not even favourite meals at anchor.
Here's one of my favorites on delivery. When moving a boat you never really know what sort of cooking tools you have to work with.
On most boats you can count on a cooker on gimbals. With respect to pasta I've never had a problem even in big seas as long as there is a pot I can use that allows a couple of inches above the water level in the pot. If the crew is small enough you can make pasta in a percolator.
My fav offshore recipe:
Lay out a pork loin in a disposable foil pan. A bit of olive oil, ground pepper, and kosher salt (go easy). Chop onions, carrots, and celery and wrap in foil - drop in foil pan. Chop new potatoes (or any small red or other low starch potato, drizzle with olive oil, and wrap in foil - drop in foil pan. Cover the pan with more aluminum foil and shove in the oven set at 350F (ish).
You do have one of these http://www.amazon.com/Taylor-Classic-Instant-Read-Pocket-Thermometer/dp/B00004XSC4/ref=sr_1_3?ie=UTF8&qid=1343653527&sr=8-3&keywords=taylor+thermometer right?
Depending on the oven somewhere between 45 minutes and 1-1/2 hours (most boat cookers aren't very well insulated and the temperature swings around) you'll get an internal temperature of 145F. Lock the gimbal on the cooker so you don't end up with everything in your lap, time the boat motion, and pull the pan out of the oven. Stick it on top of the cooker and unlock the gimbal. Let the pork sit covered for a few minutes while you assemble salads and pass them up to the crew. Slice half the roast and load up plates with the pork and roasted veg.
After dinner, slice the rest of the roast thinly for sandwiches next day.
If there is still some left you can stew them in jarred BBQ sauce, tomato paste, a little vinegar, pepper, oregano, and left over veg for an easy sort of barbecue pork.
copacabana and brokesailor like this.
SVAuspicious is offline
post #142 of 190 Old 07-30-2012
Over Hill Sailing Club
smurphny's Avatar
Originally Posted by hellosailor View Post
In the US the big brand name for tinned pasta is Chef Boyardi. After a certain young age, it is better known as Purina Bachelor Chow.
Some stuff is inedible even for us bachelors. Canned pasta is one of them. Canned Chili...now that's another story. Some of it is actually good. I keep plenty of that on board along with lots of cans of Tuna and chopped clams. It's quick and easy to make up pretty good clam sauce with chopped clams, olive oil, onions, and garlic. There have to be 100 ways to use tuna. Canned goods are great on board as long as you can keep them dry. Once they start to rust, it does not take long for them to spoil.
If you know of a good energy bar recipe, please post a link. The last two I tried were terrible so I kinda gave up on it. Used to order Clif Bars by the case when I was road biking but have never been able to come close to a DIY recipe.
SVAuspicious likes this.
smurphny is offline
post #143 of 190 Old 07-30-2012
tdw
Super Fuzzy Moderator
tdw's Avatar
I'm beginning to think you guys sail in much calmer seas than we do. Passing salad plates up to the crew ? wow.
Dave, I thoroughly agree that sailing does not have to be camping but there is still an element of camping involved particularly when you are thrashing to windward in plus twenty knots with a nasty beam sea.
Must say I did like the sound of the roast pork thing though and yes I find the oven a great boon for cooking at sea.
As for pasta, maybe I am just being a worry wart but I've been badly scalded once in my life and I never want to go through that again, indeed a couple of years back when at anchor the Wombet clipped a saucepan of water and it went over her hand. OK, so we had the means to treat it available but it was not a pleasant experience and I'll do just about anything, yes even eat re heated pasta, to minimise the boiling of water on board.
btw ... it might have sounded as if I was summarily dismissing WingNwings idea of cooking pasta in a pressure cooker. I wasn't, though I'm not sure how you monitor the progress of the pasta. We still don't have a pressure cooker, its a situation we need to remedy.
Of course rice based dishes are a damn fine idea at sea as well.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #144 of 190 Old 07-31-2012
Mermaid Hunter
Hi Andrew. I can't speak to the relative size and period of seas. What I described works for me as long as the cooker doesn't gimbal to the stops very often.
The pork loin and roast veg go on plates. The salad goes in bowls. *grin* One bowl at a time up the companionway. By the time the last one is up the first person is done and I can swap the salad bowl for a dinner plate. Downside - I end up eating salad for dessert so I can eat the main with crew. Not so bad. Weather permitting I feed crew in the cockpit since clean-up is easier and motion sickness is less of a factor; it's important to keep the crew fed.
Agree completely. I never EVER clip in to the galley. I don't want to be restrained if something bad starts to happen. U and J shaped galleys generally let you wedge yourself in so you have both hands free to cook. In really bumpy conditions I may wear my foulie bibs.
Mise en place is a big help. I do prep before starting to cook. If there isn't non-skid available, a damp paper towel under the cutting board and under some aluminum foil keeps the board from moving while you cut and chop and keeps the finished parts in place. Even better, offshore all the pieces (paper towels, foil, the foil pan for the pork loin,
I would not boil pasta if the cooker is swinging to the stops at all except in the percolator and even then only if the pot holders are beefy enough. In the pressure cooker you don't monitor the progress. You cook to time and get what you get.
I'll dig out my recipe for Meadle a la Auspicious that is a one pot PC meal that cooks the pasta along with everything else in the PC. There is a picture somewhere as well.
post #145 of 190 Old 07-31-2012
Chastened
Ajax_MD's Avatar
None of the boats I sail on have gimballed range tops. Most of what we eat underway is pre-prepared or only requires assembly, not cooking.
There is one partial exception, that is my absolute favorite. It's a riff on the southern U.S. biscuits and sausage gravy. Basically, it's a huge biscuit baked in a bundt cake pan, with sausage, a little white gravy and cream cheese baked into the middle of it. We warm it up in the oven, then slice it up and hand it out to the people on the rail.
The problem is, a female friend of the crew has the recipe and won't share it! She's hoarding it for a cooking contest. She'll prepare it for us, but won't tell us how to make it.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #146 of 190 Old 07-31-2012
Has to really be bad before I can't eat out of at least a pot. Since I am a solo sailor after its cooked on stove top held in place by restraining bars makes a great place to eat. In all but rough seas a plate and mug works since my cutting board is cut to fit snug on top of stove and being gimballed makes handy table.
DocBrauer is offline
post #147 of 190 Old 07-31-2012
flyingwelshman's Avatar
Our favourite meal, or at least the one that is most memorable, was enjoyed in our first year of sailing.
We had a long sail to anchorage (6 + hours). I took a rack of wild boar ribs, rubbed them with a dry rub and set them on the BBQ on the lowest possible setting.
The ribs cooked away while we sailed to our anchorage.
Within five minutes of dropping the hook we were tearing into melt-in-your mouth ribs.
That was about 6 years ago and we still talk about it.
1989 Hunter 30'
Southern Georgian Bay
Visualize the vastness of the oceans; the infinity of the heavens; the fickleness of the wind; the artistry of the craft and the frailty of the sailor. The oneness that may be achieved through the harmony of these things may lead one to enlightenment. - Flying Welshman
flyingwelshman is offline
post #148 of 190 Old 07-31-2012
Mermaid Hunter
Really? I've cooked on only one boat in the last few years without gimballed range/oven. I'll have to pay more attention.
I have pictures somewhere of the pots tied down on the non-gimballed stove from Panama to Guatemala.
post #149 of 190 Old 07-31-2012
Here is a one-pot meal that is easy and quick to prepare, especially if you use canned beans. I prefer to soak and pressure cook my beans because the flavour is just so much better, but I’m the first to admit that opening a can is less work. I’ve made this on board a few times and even used shrimp instead of pork (though the preparation is different- you flash-cook the spiced shrimp, set aside and only return to the pot at the end).
Pork and White Bean Chili
Ingredients:
Spice mix: (homemade chili powder)
2 tablespoons ground cumin
1 tablespoon oregano
1 tablespoon cayenne pepper
1 tablespoon paprika
1 teaspoon white pepper
1kg (2 lbs) pork loin or shoulder, trimmed of fat and cut in bite-sized pieces
500g (1lb) of white navy beans (soaked overnight and cooked) or 2 cans cooked white navy beans, drained.
1 can peeled Italian tomatoes
1 can of beer
1 small green, red and yellow pepper, cut into small squares
1 large onion, diced
3 cloves garlic, minced
1 or 2 green Jalapeño peppers, minced (optional)
½ cup fresh coriander, chopped
Salt to taste
Oil
Preparation:
Pat dry the pork pieces, rub with the spice mix and set aside uncovered. In a deep skillet, quickly sauté the onions and peppers in oil and remove while still crunchy. Set aside. In the same skillet, brown the pork pieces, Jalapeño peppers and garlic on high heat in oil (perhaps in 2 batches to sear better). Add the canned tomatoes and with a spoon and knife, break the tomatoes into smaller chunks (or use “chopped” canned tomatoes). Add the rest of the spice mix, salt and about half a can of beer, cover and simmer on very low heat for 20 minutes. Add the drained beans, half the fresh coriander and sautéed onion and peppers and cook for another 3 minutes. Garnish with the remaining coriander and serve.
tdw likes this.
Vindö 50
copacabana is online now
post #150 of 190 Old 07-31-2012
Mermaid Hunter
Left to right: Carlos, me, George; photo credit to Anja
Photo somewhere West of Plymouth England enroute to Azores
Meadle is the name my Mom gave a stove-top casserole we often had when i was a child to help stretch meat. The proportions of pasta to meat are pretty forgiving and subject to adjustment based on how much of the other ingredients you have and how many people you are trying to feed. I adapted it for my pressure cooker. This recipe feeds me for two or three meals, sometimes four, depending on how hungry i am and what else i make.
1 cup uncooked pasta (any small pasta shape works well; I use elbow macaroni)
½ lb ground beef (i prefer lean)
2 cloves of garlic, minced or 1 tsp prepared crushed garlic
1 medium onion
3 or 4 small to medium tomatoes
or
½ to ¾ of a 15 oz can of stewed, crushed, or chopped tomatoes
1 small to medium bell pepper
1 tsp oregano
salt & pepper
I usually make meadle with elbow macaroni. rustle through your vegetables and pitch in whatever is about to go bad. hot peppers, carrots, celery, and cauliflower work well. mushrooms tend to disintegrate, but leftover cooked mushrooms or canned mushrooms added after cooking work well.
In a 4-quart or larger pressure cooker, brown ground beef over medium heat until it crumbles. Pour off the drippings. Stir in the rest of the ingredients. Add the pasta and just enough water (or stock) to barely cover the pasta. Lock the lid in place. Bring to 15psi over high heat, immediately reduce the heat to the lowest possible setting to stabilize and maintain that pressure. Cook 6-8 minutes. Remove from heat and use the natural release method (if you are patient ) before opening the lid. Transfer to a serving dish. You can sprinkle your choice of cheese over top (feta is great, parmesan is as well).
This dish keeps pretty well, and if sealed in bags with a vacuum sealer can be reheated in the bag in boiling water (even boiling sea water) so you won’t make another pot dirty.
Donna_F, tdw, T37Chef and 2 others like this.
Off-Season Sailing Seminars Dobbs Davis Learning to Sail Articles 0 12-05-2001 07:00 PM
How Other Sailors Learned Mark Matthews Learning to Sail Articles 0 08-31-2001 08:00 PM
Great Books for Beginners Mark Matthews Gear and Maintenance Articles 0 01-27-2000 07:00 PM
Are the Kids on a Sabbatical? Micca Hutchins Learning to Sail Articles 0 04-04-1999 08:00 PM
