Offshore 33 (I think) - SailNet Community
 1Likes
  • 1 Post By Jeff_H
post #1 of 6 Old 11-22-2016 Thread Starter
Helllo, I'm new to the forum and a new (to me) Offshore 33 owner. I just purchased an insurance boat that they had listed as a Clearwater Custom 32.2. My research has led me to believe that this is the Offshore 33. Please correct me if I'm wrong. Anyway, it is missing the forward mast/boom as it was broke during a storm. Other mast is laying on deck. My question (one of many) is how hard is it going to be to find a replacement mast? Or could I just turn it into a single mast forward, like the Nonsuch 33? I assume the diameter of the mast would be the same. What do you think? Thanks for your input.
klmiller37 is offline
post #2 of 6 Old 11-22-2016
RichH's Avatar
Re: Offshore 33 (I think)
Two versions of the Offshore 33 to choose from:
1. A Cheoy Lee designed (1971)mast head KETCH: OFFSHORE 33 (CHEOY LEE) SLOOP sailboat specifications and details on sailboatdata.com, & OFFSHORE 33 (CHEOY LEE) sailboat specifications and details on sailboatdata.com
2. A Water Scott designed (1978) Cat-Ketch: OFFSHORE 33 (SCOTT) sailboat specifications and details on sailboatdata.com The Cat-Ketch rig is unstayed ("wishbone" type boom system, w/ no rigging). Looks pretty much like the one you bought.
Its not going to sail very well at all with just one mast. A 'good rigger', will be invaluable in locating and installing the replacement.
Good Luck with your new boat!!!
RichH is offline
post #3 of 6 Old 11-22-2016
krisscross's Avatar
I'm afraid that a new carbon mast for your unstayed rig will be obscenely expensive. Not sure if you can move the aft mast to replace the forward rig. You might be able to sail with the forward rig only but not with aft rig only. I would start looking for a used carbon fiber mast right away. And prepare to drive long way to get it.
Plato
krisscross is offline
post #4 of 6 Old 11-22-2016
The masts in these were aluminum not carbon. Find a used light pole from a parking lot as they spec about the same as the originals.
Sent from my Pixel C using Tapatalk
Bleemus is offline
post #5 of 6 Old 11-23-2016
Go with Rich's suggestion here. Hire a rigger to figure out how to fix this right. Whatever alterations you make to rig the boat a different way than it was designed will end up costing you more. Depending on how much damaged the storm caused be prepared to spend a lot of money getting the boat sailing again. You might be able to save some money by doing some of the legwork for the rigger but you should have someone to make sure you do it right and then rig it for you.
It looks like a lot of boat to be sitting on only two axles.
Jordan
West Wight Potter 14 "Lemon Drop"
Oceanside CA
jephotog is offline
post #6 of 6 Old 11-23-2016
Moderator
Jeff_H's Avatar
The spec for light poles and for aluminum freestanding masts are not at all alike. While there were manufacturers of boats with aluminum masts who turned to light pole manufacturer's for their spars, those spars had an extremely different specification than the light poles. Aluminum spars are generally 6061-T6, which is a structural grade of aluminum that has good corrosion resistance. Aluminum freestanding spars were usually 6061-T8 or 6061-T9 aluminum, which are higher tempered versions of 6061-T6.
Light poles are typically 6063-T3 which is much lower strength (only 80% of 6061-T6), 'non-structural' product with only moderate corrosion resistance that is mostly used for architectural features in buildings.
The masts also typically had thicker walls than the light poles as well.
It may be possible to get a light pole manufacturer to construct a mast section out of 6061-T6 and temper it to T-6, or T-8. But it would probably be considerably more expensive than a stock light pole, and perhaps with the new boom and sail more expensive than the boat would be worth if retored and with the spars in place.
That does appear to be an Offshore 33. It would not sail worth a darn with only one stock mast no matter where you placed it. The Nonesuch was designed from scratch as a system to be catboat. The Offshore 33 was not; being designed from scratch to be cat ketch and so the stability, keel profile etc, does not lend itself to that adaptation to a catboat.
ebourg likes this.
Jeff_H is offline
Offshore in a 24' tager Cruising & Liveaboard Forum 38 02-12-2010 08:48 AM
offshore 33 hairtickles General Discussion (sailing related) 2 11-26-2009 07:11 AM
Offshore performance of a Beneteau Oceanis 500 offshore JohnVerver Introduce Yourself 1 05-23-2009 12:40 PM
VC Offshore mikehoyt Racing 8 06-30-2007 09:03 PM
Offshore 33 ? DirtManly Boat Review and Purchase Forum 0 07-19-2002 08:09 PM
