Keel Bolts REPAIR Info. request. - Page 2 - SailNet Community
post #11 of 12 Old 12-29-2006
A cast iron keel in that size may be light enough to be removed from the boat and brought to a sandblast facility. If it can be thoroughly cleaned, then you can remove or drill out the old bolts and perhaps tap for new.
When you are working with clean cast iron, it can be coated with epoxy primer and something like VC Tar or Interprotect that will smooth it up and prevent future corrosion.
Good keel bolts are peace of mind when sailing hard.
Goodnewsboy is offline
post #12 of 12 Old 01-02-2007 Thread Starter
hooyasailor
Send a message via Yahoo to hooyasailor
Hey! Goodnewsboy,
Thanks for the reply! Sounds logical. I've never done a task like this, looks like I've got my work cut out for me, not an easy one at that. I've been on the boat all weekend and nothing is going to be easy on this repair job. Every time I get into completing one thing, two new "most do's" pop up. I should get to sail her in a couple of months. What ever, all this has given me the name for my new/old Clipper Marine. "TOO MUCH' that's her new name. Fortunately the previous owner had not named her, so I will not have to contind with the neptun gods and going through the name change ritual. thanks again for the details.
Fair winds,
Hooyasailor
hooyasailor is offline
Fixed or swing keel, which is better? TimG2 General Discussion (sailing related) 17 07-30-2014 09:23 AM
Fin Keel or Shoal Keel acmecoyote General Discussion (sailing related) 11 05-06-2011 04:39 PM
reducing keel/adding fin? abacosol Gear & Maintenance 9 07-01-2007 09:32 PM
Keel Bolt Repairs Don Casey Gear and Maintenance Articles 0 11-10-2003 07:00 PM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 08:00 PM
