Keel Bolts REPAIR Info. request. - SailNet Community
post #1 of 12 Old 12-27-2006 Thread Starter
hooyasailor
Send a message via Yahoo to hooyasailor
Ahoy! Is there any one out there that has knowledge about the details involved with replacing the keel bolts (Rusted) on a Clipper Marine 23 foot sailboat?
I have inquired locally, with the yards and the prices range from arround six to eight hundred to 3 or 4 K. So, before commiting to putting her on the hard for a couple months and being grounded , I'm checking out doing it myself. Any suggestions or first hand knowledge that will assist in avoiding pit-falls will be greatly accepted.
Thanks, in advance for your reply.
hooyasailor
hooyasailor is offline
post #2 of 12 Old 12-27-2006
try this link
http://67.123.120.75/~mike/CM26/Keel/
seems faily complete . . .
avant is offline
post #3 of 12 Old 12-27-2006
pigslo's Avatar
keel bolts
you can also do a search on sailnet as this topic has been extensively covered
pigslo is offline
post #4 of 12 Old 12-27-2006
Does it have a fixed or swing keel? Is the keel cast iron or lead or other?
Sailormon6 is offline
post #5 of 12 Old 12-27-2006 Thread Starter
hooyasailor
Sailormon6,
Clipper Marine MK23, She is a twin keel boat, draws about 24 in of water. The bilge (What there is of it) is only about four to six inches deep. The nuts holding the keel bolts are almost rusted off. This boat was a recent "Gift". I have been fixer-up'n it for the past two months. Actually, the boat is in really good shape, after a good cleaning. However, I am concerned about the seaworthness of the vessel, what with the bolts in the bad condition they are. I'm just looking for comments from fo;ks that have tackled this type of problem. Thanks for your reply,
hooyasailor
post #6 of 12 Old 12-27-2006 Thread Starter
hooyasailor
seems fairly complete . . .
THANKS, for the info/web site. PROBLEM, Mine is a twin keel, not a swing keel. I can see that Mike had a fairly easy project with his boat. I am afraid my job will be much more complicated and probability four times the work. I'm still looking if you have anything as good as this for twin keels, fixed cast iron.
hooyasailor
post #7 of 12 Old 12-27-2006
Nuts are often made of inferior metals, not the same stainless or bronze that keel bolts are. And, even with stainless nuts, sometimes plain steel washers are used with them.
So you might want to use a nut cracker, or a Dremel tool, to split off just one keel bolt NUT ONLY, from the center of one of your keels. Then use some rust remover to clean up the keel bolt, and see if the bolt itself is a problem--or just the nut.
If the nuts are the only problem, remove them and replace them one at a time. Check for the size of the nuts and make sure to retorque the new ones to the proper torque range. I'd apply a generous amount of threaed lock (LocTite) to lock and seal the threads, then apply a generous coat of something like beeswax over the whole, to waterproof it. (Easy to remove for inspection, sticks well, durable enough, cheap.)
hellosailor is offline
post #8 of 12 Old 12-27-2006
hooyasailor, go to the following website for a discussion on replacing keel bolts in a cast iron keel on a Catalina 25. If your keels are cast iron, the process should be about the same. For more specific info, join the forum and ask the members. There's no charge and you don't have to own a Catalina to join.
http://www.catalina-capri-25s.org/fo...erms=keel+bolt
post #9 of 12 Old 12-28-2006
Alex, not full of crap
werebeagle's Avatar
And if you need a good cheap supply of beeswax, just go to the local home improvement store and buy a toilet wax ring.
Charlie
werebeagle is offline
post #10 of 12 Old 12-29-2006 Thread Starter
hooyasailor
Wink Great Info - Thanks
Sailormon6,
This web is great. Good photos of the keel bolts, (Only wish mine looked that good) problem is mine are in really bad condition. One bolt is almost completely gone from rust. I've got a big job ahead, but thanks for your input, now I'll be letting you know when you should come over, so we can get started on replacing these rusted keel nuts. By the way,,, do you have a good heavy duty side grinder you can bring alone. see ya in a couple months, after I get her back into the water.
hooyasailor
ps. Thanks to the other tips, "bees wax" werebeagle; hellosailor; pigslo,, OH YES,, We'll be expecting all you guys over for this tesk, it should-outta go quickly that way. You sure are a great gang to offer to help out this way.
(SNIP)
http://www.catalina-capri-25s.org/fo...erms=keel+bolt[/quote]
Fixed or swing keel, which is better? TimG2 General Discussion (sailing related) 17 07-30-2014 10:23 AM
Fin Keel or Shoal Keel acmecoyote General Discussion (sailing related) 11 05-06-2011 05:39 PM
reducing keel/adding fin? abacosol Gear & Maintenance 9 07-01-2007 10:32 PM
Keel Bolt Repairs Don Casey Gear and Maintenance Articles 0 11-10-2003 08:00 PM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 09:00 PM
