Divinycell (PVC) Used on Giulietta - SailNet Community
post #1 of 3 Old 01-05-2007 Thread Starter
After I posted construction of Giulietta, I received a lot of PM from a lot of people asking me what was the Divinycell.
I replied once, twice, then on the fifth PM I decided to post here what it is and the web page of the brand that was used for the construction of my boat.
They have here all the different densities and purposes.
The Diviniycell is like a lighter stronger styrofoam, tha comes in sheets and can be cut with a knife and sanded just like foam on a surfboard.does not rott, and makes the boat unsinkable (I hope!!)
Basically you make it to whatever shape you want, fiberglass one side, turn piece around, remove wood structure used to help it keep its shape, then fiberglass the other side. The result is a 25mm thick chunk of very light very strong fiber glass, wity minimal structure required to keep its strenght.
I believe was around $90 each sheet (here)and a lot was used, over 150 sheets if I am not mistaken. Don't know exactly.
Thank you.
http://www.diabgroup.com/americas/u_...u_prods_2.html
For the tech freaks here is some more stuff
http://www.carmas.com.ar/DOWN/DIVINYCELL/HBook.pdf
Giulietta is offline
post #2 of 3 Old 01-05-2007
T37Chef's Avatar
Thumbs up
Thanks G,
This could be very useful when I tackle that spongy deck spot near the bow.
T37Chef is offline
post #3 of 3 Old 01-06-2007 Thread Starter
If you need further assistance, please do ask.OK??
If I can't answer, I will ask my friend who built my boat. He is very very experienced with Divinycell and its "tricks".
He is now reparing a racing B&C made in Argentina, that felt off its stand. This particular one has a very thin fiberglass layer on the outside and no gel coat, its just painted.
Construction of GIULIETTA Giulietta General Discussion (sailing related) 35 01-24-2007 06:16 PM
PVC foam core rbh1515 Boat Review and Purchase Forum 2 01-08-2004 09:35 AM
PVC and Epoxy billmac26 Gear & Maintenance 3 02-18-2003 12:12 AM
