Mast types...? Through deck on deck...? - Page 3 - SailNet Community
post #21 of 42 Old 01-18-2007
Thanks Courtney.
Thanks for posting the photo G-. I had saved it to my computer but, as usual, couldn't get it on to a post! Now could you put the Ken Barns photo up???
I may be wrong, but I just don't see a keel stepped mast taking out a section of deck. It seems that the mast would exert lateral force on the partners during a dismasting which would be far less likely to fracture the deck than upward or downward force.
I do agree that neither options is more, or less likely to fail, if built correctly. Dismasting would be more of a failure of the rigging and chainplates than the mast itself.
hunter Legend 37 Semper Paratus
Formerly - Tartan 34C Yawl
T34C is offline
post #22 of 42 Old 01-18-2007
Best Looking MALE Mod
Cruisingdad's Avatar
I think johnsail could provide some real insight into this. I think he wrote a book on the Fastnet race. Again, we are talking extreme conditions, but I would love to hear from another expert.
Cruisingdad is offline
post #23 of 42 Old 01-18-2007
Zanshin's Avatar
I envision several mast failure modes but the most likely that I see is a stay failing and the resultant assymetrical forces breaking the mast. In this case the lateral forces on a keel stepped mast would make the failure point either the deck (if the deck is stronger on a horizontal plane than the mast) or {horror} the mast pivoting around the keel mounting point and tearing away a large chunk of the deck before {hopefully} being pulled out. This mode couldn't happen with a deck stepped mast, even after sliding off the mounting harpoint the forces would be more lateral than vertical.
look at 2 distinct failure modes - mast breaking above deck and
Zanshin is offline
post #24 of 42 Old 01-18-2007
At your service.....
Giulietta is offline
post #25 of 42 Old 01-18-2007
Thanks Courtney.
Thanks G- !!
I would guess that is typical of deck stepped mast breakage like the previous photo. The force being applied at the masthead by the halyard and having an oposing force at the lower shrouds.
T34C is offline
post #26 of 42 Old 01-18-2007
I think the reason a keel stepped mast often damages the deck is that it does break higher up..and the mast falls and punches a hole through the deck where it hits. A deck-stepped mast usually breaks at the mast step and gets swept from the deck, not damaging the deck much otherwise.
sailingdog is offline
post #27 of 42 Old 01-18-2007
Señor Member
TrueBlue's Avatar
Both masts on my ketch rig are deck stepped, and based upon the conclusive reasoning in this thread, I'm glad I have less potential for double trouble.
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #28 of 42 Old 01-18-2007
Thanks Courtney.
SD- I think that is a good point, but with the force on the sail I would guess the masthead is "most likely" going to fall over the side. There is the possibility that I think Jeff mentioned that the keel stepped mast wouldn't shear off or break, but bend over (fold) and need to be cut off of the stump.
T34C is offline
post #29 of 42 Old 01-18-2007
OHHHH My!!!! Jesus, Mary, and Joseph!!!
Where this is going.....soon Michael Moore will be writing about this, too
post #30 of 42 Old 01-18-2007
Thanks Courtney.
I think this thread has already included more facts than MM.
Boy G- you sure know how to throw fuel on the fire!!
T34C is offline
Deck vs. Keel Stepped Masts Envirella Gear & Maintenance 10 11-29-2009 12:06 PM
which 38ft boat? bluewaterdreamer Boat Review and Purchase Forum 10 10-03-2007 01:54 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 06:33 PM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 08:00 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 07:08 PM
