  #11 (permalink)
Old 01-19-2007
capecodphyllis's Avatar
capecodphyllis is an unknown quantity at this point
Originally Posted by halekai36
I have experience and actual results, of the comparison you are looking for...
We had a 10 foot AB Rib Light series... and replaced it with the IIDENTICAL RIB only 2 feet shorter.... Our ten footer would plane two people with ease with a Yamaha 8hp two stroke motor. With the same exact motor (we kept that) and the same model RIB just two feet shorter we could not get on plane at all! No plane nada, none, no can do. Longer is better think surface area.
Thank you!
And it doesn't matter why (other than being interesting to talk about). Increased buoyancy, longer waterline, or a combination of the two, the FACT is that despite the significantly greater weight of the larger RIB, it will both plane sooner and go faster with the same motor.
Of course, if you move up to a 14' or 16' RIB this would probably not be the case. As weight would overcome available horsepower. Just goes to show that one must put alot of thought into RIB/Hp choices.
RIB sellers should provide statisitcs about hp/planing requirements under various loads for a given model
As far as 2-strokes. I'm not gonna go there, because they don't make 'em anymore.
  #12 (permalink)
Old 01-19-2007
Maine Sail's Avatar
Yamaha does they still sell the 8, 10 & 15 hp in two stroke but probably not in CA... Port Harbor Marine in Maine stocks and sells a slew of them because no one wants the small 4 strokes due to complexity and weight....
______
-Maine Sail / CS-36T
Pilot dies in crash of small plane in Gladwin County lake - WLNS NewsReader News Feeds 0 11-16-2006 02:16 AM
Pilot found dead after plane crashes in lake near Midland - MLive.com NewsReader News Feeds 0 11-16-2006 01:15 AM
Hope of plane sailing (icWales) NewsReader News Feeds 0 09-29-2006 12:15 AM
COST-EFFICIENCY IS PLANE SAILING (Bangkok Post) NewsReader News Feeds 0 09-27-2006 04:15 PM
Plane sailing for Sam's skydive (St Albans Observer) NewsReader News Feeds 0 08-23-2006 05:16 AM
