My copper wire doesn't conduct (???) - SailNet Community
 2Likes
post #1 of 21 Old 04-06-2017 Thread Starter
TakeFive's Avatar
I've been trying to wire a new RAM mic in my cockpit (as described on another thread). I removed the old RAM mic (which was working fine), and planned to re-use its wire so I don't have to re-run the new wire through the binnacle guard. So I clipped off the connectors at both ends of the old wire, and tried to splice the new connectors onto the old wire. I've had difficulties getting a good splice, which I had attributed to the splicing connectors that I was using being incompatible with the very tiny gauge wire. I just tried some new connectors, and they did not work either. So I went and did some continuity checks on the wire itself, and was shocked to see that the copper wire does not appear to conduct electricity.
In the pics below, you can see that I took the copper shielding wire and wrapped it around both probe tips, and show no continuity. For you cynics out there, the second picture shows clearly that when the probe tips touch each other, there is continuity, so it does not appear to be a problem with my cheapo multimeter. FYI, the copper strands do not appear to have any sort of clear lacquer or other insulating material on them. I tried checking continuity of some of the other conductors, and had the same problems.
As I mentioned before, the old RAM mic that was connected with these wires worked fine. (I'm replacing it because I upgraded my VHF to a new model, which needs a new model of RAM mic.)
Does anyone have any suggestions?
Rick S., Swarthmore, PA
TakeFive is offline
post #2 of 21 Old 04-06-2017
Dirt Free
boatpoker's Avatar
Re: My copper wire doesn't conduct (???)
You appear to be testing two wires coming out of one end of the cable. What colours are contacting your probe in photo #1 ? You can't test continuity at only one end of the cable. You need to test a wire for continuity from one end to the other. i.e. one end of the black to the other end of the black.
What you can test at one end of the cable is voltage between red and black which will tell you if there is power there.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #3 of 21 Old 04-06-2017 Thread Starter
TakeFive's Avatar
I am not testing two different wires in this picture. The colored insulated wires you see are just dangling off the side, and not part of the test.
I had initially tested the uninsulated copper shielding wire at both ends and got no continuity. For purposes of this picture (since I only have two hands, and wanted to keep everything compact to snap a close-up) I took a 1.5" length of the copper shielding strands that were coming out of one end of the wire bundle, and wrapped that short length around both probes. So in this case I see no continuity through a 1" length of copper wire!
The wire is disconnected - it's not carrying any voltage. I'm measuring resistance to determine continuity.
TakeFive is offline
post #4 of 21 Old 04-07-2017
overbored's Avatar
must be a coating on the wire or there is just enough oxide on the wire to not pass any current. scrape the wire to get clean copper and test it. I have seen this happen on copper ground connectors on aircraft. we had a 5/16" stud for ground and a brand new ground strap with no continuity through the connection. surface oxide was enough to stop any electrons.
seabeau likes this.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #5 of 21 Old 04-07-2017
Mermaid Hunter
SVAuspicious's Avatar
First: https://www.fastenal.com/products/details/0710538
The lack of continuity is odd. My first guess is varnish. Scrapping or sanding can work but is frustrating. Try burning it off with a lighter or small torch.
SVAuspicious is offline
post #6 of 21 Old 04-07-2017
4KSB driver.
SHNOOL's Avatar
Dock
I vote burn... must be oil or wax or something... but his question is more serious, because if he cannot get good conductivity to the ground plane, on one end, anyone realize how cruddy it must be at the other?
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is online now
post #7 of 21 Old 04-07-2017 Thread Starter
TakeFive's Avatar
Hi John, I am not working with the actual wire on the boat, I am doing my splice testing in the comfort of my home with an excess piece of wire that I clipped from inside my cabin. The wire's condition is pristine - no corrosion at all, just perfectly shiny copper wire.
I'll try Dave's suggestion of burning off any varnish layer and redo my test on the bare-looking shielding conductors. But the wire strands inside the colored insulation also failed continuity. Would those be varnished also?
TakeFive is offline
post #8 of 21 Old 04-07-2017
Mermaid Hunter
Hmm. Seems unlikely. Please report back.
post #9 of 21 Old 04-07-2017
4KSB driver.
SHNOOL's Avatar
Dock
Yeah, seems very unlikely... and its enough of a problem that I'd call suspect on all of the wire. In your situation I'd create a loop of the existing wire, burn/tin the ends with solder to verify good conductivity, and retest via the ends.
Sometimes the coating on the probes are funny with dissimilar metals as well. Its rare, but I've been bitten by it before. Actually Ive seen voltage drops at a distance measured from the battery for the same reason... test and get 4-8V, then test again and get 12V, then 4-8, and its merely the probe not making complete enough contact... but for sure this is pretty odd indeed.
post #10 of 21 Old 04-07-2017
My vote is for an intermittent connection in your meter leads. It's all just coincidence. Sometimes they conduct, sometimes they don't. Broken wire?
MarkSF is offline
heat exchanger, copper or copper/nickel? douglasb Diesel 5 07-19-2014 10:33 AM
Oman Sail to conduct ‘Try Sailing' programme NewsReader News Feeds 0 09-14-2012 07:30 PM
Wisconsin Rep. Brett Hulsey convicted of disorderly conduct - Green Bay Press Gazette NewsReader News Feeds 0 08-31-2012 04:30 PM
Sar Techs Conduct Daring Sailboat Rescue - Canada.com NewsReader News Feeds 0 07-21-2012 04:50 AM
Copper wire for marine use? TakeFive Gear & Maintenance 9 05-16-2010 10:00 PM
