01-20-2007
Wandering Aimlessly
Most A/P's accept nema input, which is what SeaClear would have to send to follow a route you have laid on there. To do that, you'll need a usb to serial (9 pin) cable. Then you'll need either a female 9 pin end, with wires soldered onto the negative and output terminals, or buy a serial cable and cut it down to those two wires. I forget, offhand which two terminals you want from the serial plug, but I believe it's 3 and 5. A google search should get you that info. Once you have that, you can plug the two wires into the nema input on the A/P.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love. JCP
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. - Website & Blog
