Old 01-20-2007
rickheaverly is on a distinguished road
slip size
what is the narrowist slip size for a boat with a 10' 5" beam
thanks, rick
Old 01-20-2007
camaraderie's Avatar
moderate?
ahhh...10'6". What is the point of the question?
Old 01-20-2007
Actually, you could go 10' 5" but you'd have some problems with rubbing the paint
Old 01-20-2007
T34C's Avatar
Thanks Courtney.
T34C has a spectacular aura about T34C has a spectacular aura about T34C has a spectacular aura about
You could go 10' 0" if you go fast enough!
Maeven
Tartan 34C Yawl #282
Anything-sailing.com
Moderator
Old 01-20-2007
jones2r is on a distinguished road
IIRC, the Panama Canal is 105ft. wide, and the Missouri is 103ft. wide. So, if you scale your boat's length to the Missouri's length (don't know that number OTTOMH) and then calculate the corresponding lateral tolerance, it could be a fair basis of comparison.
Hope this has been helpful.
[After supper on a Saturday night may not be the best time to ask a technical question.]
Old 01-20-2007
SailinJay is on a distinguished road
I'd want at least a foot clearance on either side of the boat, so I'd say that you'd want a slip that is at least 12.5 feet wide.
Old 01-20-2007
pigslo's Avatar
pigslo is on a distinguished road
You guys!!! I would want a slip 12 feet for that boat. I like a wide slip so that there is lots of leeway for tidal range or when the water all gets blown out of the marina.
pigslo
Old 01-20-2007
SailinJay and Pigslo are ruining all of our fun. You probably do want at least a foot of clearance on either side. It depends on whether your slip has finger piers on both sides or on one side with and another boat on the other.
Old 01-20-2007
pigslo's Avatar
And don't forget the clearance under the boat. If the slip is not deep enough you will have to have the big truck come in and fill it with water!
pigslo
Old 01-20-2007
moderate?
Rick...consider yourself welcomed to sail net! We're a funny group!! (EXCEPT FOR GIULIETTA)
Have 37'Endvr with liveaboard slip in Daytona firemanbob55 Living Aboard 0 10-20-2006 02:28 PM
Slip Width johar General Discussion (sailing related) 7 09-27-2002 09:46 AM
