Serious Waves - SailNet Community
 10Likes
post #1 of 11 Old 04-18-2017 Thread Starter
davidpm's Avatar
Serious Waves
https://gfycat.com/FickleEasyGoldfinch
Minnesail likes this.
davidpm is offline
post #2 of 11 Old 04-18-2017
Master Mariner
capta's Avatar
Re: Serious Waves
I'm thinking how good a nice long hot shower would feel after THAT race!
facebook.com/svskippingstone
Our Videos;
capta is online now
post #3 of 11 Old 04-18-2017
Re: Serious Waves
I wish the video was longer.
I'm guessing the skipper knew that boat and was comfortable.
They are powered up.
RegisteredUser is online now
post #4 of 11 Old 04-18-2017
Gail Peterson's Avatar
Re: Serious Waves
I recall sailing in some rather gnarly conditions in 2001 aboard a Catalina 30 my then husband and I had purchased that we were delivering from Deltaville, VA to Deale, MD. The Annapolis to Newport race was underway and Hurricane Allison was downgraded to a tropical storm and was forecast to head briskly out to sea. The entire trip should have taken about 6 hours at a leisurely pace. Weather checks were made and the sky was partly cloudy and the winds fresh...
Well, that didn't last. Allison decided she wanted to stick around for the race and joined up with a friend of hers, "Low" (we nicknamed it the almost perfect storm) and when we had reached the Calvert cliffs, winds had picked up to 60 sustained, the rain was completely horizontal, and the waves were sending green water up to our mast as the Catalina's nose dove into the confused sea.
While passing the racing fleet, we heard at least 5 man overboard calls and several boats bailing out of the race due to the worsening conditions. We made the decision to make a run to Solomons as none of us had the strength to safely go any farther. 12 hours after heading out, we finally reached the protected cove of Solomons. We found an empty slip and tied off for the night. We were a crew of drowned rats, cold to the bone and all of our layers of clothing sticking to our skin in awkward bulges under our foulies.
The next morning the skies were clear and the air crisp. While walking to the office to let them know of our unplanned arrival, we looked out into the channel and noticed that the water level was VERY low. In fact, no boats with a draft greater than 3' could make it out. Thankfully, the people at Zahnisers did not charge us for the slip and allowed the boat to remain until the 5.3' draft could clear the channel. Great people there!!
I learned a huge amount on that sail and have a very deep respect for our mother nature while enjoying life in our little boats....
Slayer, davidpm, CalebD and 4 others like this.
1973 Cutter-Rigged Pearson 39 "Brandy"
______________________________________________
"Mama always told me not to look into the eyes of the sun. But Mama, that's where the fun is...." ~Manfred Mann's Earth Band
Gail Peterson is online now
post #5 of 11 Old 04-19-2017
Moderator
Jeff_H's Avatar
Re: Serious Waves
Neat little video. One of the surprising things to me about sailing smaller boats in big waves is what happens in the troughs. If the waves are big enough and steep enough, there is usually a lull in the wind when you are in the trough that occurs because the wave itself blocks the wind some. Its not a big deal when you are deep reaching or running, but going upwind it can have a profound effect as the boat slows dramatically as it tries to climb the face of the next wave. And then as you get to the top of the wave and are fully exposed to the wind, there is a tendency to knock down.
In very steep wave conditions, I found that it was important to maintain the right amount of speed, and the right angle to the wind. If you go too slowly the boat can actually be stopped, losing steerage, and even be pushed backwards against the rudder. Too much speed and the boat can be launched violently off the top of the crest and come down very hard (especially if you miss a major portion of the back of the wave).
In terms of the angle to the wind, the boat (even on a vane), does not steer at a constant angle to the wind and waves. Talking through the cycle of passing through a set of large steep waves, starting as the boat starts down the wave from the crest....At the top of the wave the boat is exposed to the full force of the wind and so the apparent wind is lifted and the boat heels over aggressively and starts to accelerate as the boat starts down the back of the wave. As the boat moves down the windward side of the wave, the boat speed increases due to surfing, and the wind speed decreases as the the wind is blocked by the next wave so the apparent wind is a header, and the tendency is to fall off to maintain speed and control. As the boat starts to climb the next wave the boat speed decreases and the wind speed also decreases and the apparent wind angle remains roughly the same. But as the boat starts to climb the wave and feels the full brunt of the wind, the wind angle quickly becomes a lift and the boat needs to head up to keep from knocking down.
Because a vane steers by apparent wind, it automatically does some of the right corrections. How successful the vane (or human) will be is dependent on carrying just the right amount of sail. There needs to be enough sail up to keep the boat at speed in the troughs, but not so much sail that the boat knocks down or develops uncontrollable weather helm at the crest. In those conditions a boat with minimal drag for its stability will generally do better than a boat that is high in drag relative to its stability because the low drag/ high stability boat can get by with less sail area and can stand up to its sail area better than a higher drag boat.
Jeff_H is online now
post #6 of 11 Old 04-19-2017
al brazzi
Re: Serious Waves
Gail, good story and Post. Youre no longer a junior member anymore
Gail Peterson likes this.
albrazzi is online now
post #7 of 11 Old 04-19-2017
Re: Serious Waves
Jeff, do you find that when sailing in such conditions, you have to sail at a rather steep angle going up the wave, then turn into it a bit when cresting so that the wave does not take hold of the keel and throw you over? That's is what it felt like we had to do (we were going upwind, if that makes any difference).
Also, would someone sailing a full keel boat have to maneuver the waves differently than boat with a fin?
Thanks for you insight.
post #8 of 11 Old 04-19-2017
Moderator
Jeff_H's Avatar
Re: Serious Waves
My experience with large steep waves was in the Atlantic over the shallow shelf in Georgia where the winter and spring waves could build to 12-15 feet with an occasional larger wave thrown in. Typically either the windvane or the helmsman would feather up into the wind slightly as crossing the crest of the wave, and would fall off slightly on the way down the windward side of the wave. This worked well with centerboard and fin keel boats and made for a comparatively smooth ride if you didn't try to get too much speed or did not lose too much speed climbing the leeward side of the wave.
It was much harder with a full keel boat since you had to carry proportionately more sail area to make the climb up the leeward side of the wave, and the height of that sail area was lower to the water so it would be blanketed longer in the trough. Typically you would have almost no speed and no steerage by the crest of the wave, and so would get pushed back onto the rudder and/or not be able to feather up and so would take a large knockdown at the crest. As the boat would start to move forward again, there would be a lot of weather helm so it was hard to keep the boat on a course that would build speed for the next climb.
But the worst that I experienced was on boats that had a deeply cut away forefoot and keel hung rudder. The two examples that come most sharply to mind was a 1908 Herreshoff design and the other was an Alberg 30. These old girls beat you to death. With their short water lines they did not track like the full keeled boats and with their less effective keel hung rudders you could not steer your way through the waves. We ended up powering up the Herreshoff a little after being tossed back against the rudder so hard that we were afraid that it would be damaged. But in doing so, we were taking some pretty hard knock downs and had vast amounts of weather helm.
post #9 of 11 Old 04-19-2017
midwesterner's Avatar
Re: Serious Waves
Originally Posted by Jeff_H View Post
My experience with large steep waves was in the Atlantic over the shallow shelf in Georgia where the winter and spring waves could build to 12-15 feet with an occasional larger wave thrown in.....
I'm wondering how a boat like a Bristol 35.5 or a Cape Dory 33 would compare to the Alberg 30 or the Herreshoff?
midwesterner is online now
post #10 of 11 Old 04-19-2017
Re: Serious Waves
Reminiscent of NARC 2002. We did it in a Cabo Rico 45.
captndave1 is offline
learning about waves... boknows Learning to Sail 20 02-07-2014 07:51 PM
Steering through the Waves?? Shack Seamanship & Navigation 5 09-13-2006 05:31 AM
How to Steer in Waves Carol Cronin Racing Articles 0 06-10-2002 08:00 PM
