leak-proof keel stepped mast idea - Page 3 - SailNet Community
post #21 of 28 Old 01-25-2007
Originally Posted by werebeagle
I'm just glad I ate lunch before I read those last couple of posts.
LOL... I can understand why... my post definitely does not bring up the prettiest image...
sailingdog is offline
post #22 of 28 Old 01-25-2007
Alex, not full of crap
werebeagle's Avatar
I've still got chills from that image.
werebeagle is offline
post #23 of 28 Old 01-14-2010
RAGTIMEDON's Avatar
I'm glad I DIDN"T eat lunch before -- I probably would have lost it!
Don
1980 Endeavour 37 sloop, currently in the Mississippi near St Louis
RAGTIMEDON is offline
post #24 of 28 Old 01-14-2010
SaltwaterSuzi/CapnLarry
LarryandSusanMacDonald's Avatar
And I thought you guys understood boats.
Here's the thing about leaks - if you want them to leak, they won't. So any deck leaks, any mast step leaks should be incorporated into your water collection system. Ergo, no longer a problem.
I have noticed that deck scuppers and cockpit drains can be completely negated by a single little leaf, able to hold back many gallons of water.
You have seen it too, I am sure.
So forget fancy mast boots; don't even consider tubes of caulk, or any other anti-leak schemes. Place a leaf above any suspected source of leak or place a hose that will shunt any deck leak into your water tank. The leak will vanish.
If that fails, always remember, without deck leaks, how would you know where to store your buckets?
Saltwater Suzi and Cap'n Larry
"A sailboat is a fickle mistress. You’ve got to buy her things. You’ve got to understand everything about her. What you don’t know she’ll use against you." -Captain Larry
LarryandSusanMacDonald is offline
post #25 of 28 Old 01-14-2010
tager's Avatar
I am 100% sure that you can design it not to leak. There have been bigger engineering challenges in the history of man. It is just the fact that there is no simple and economical solution that causes manufacturers to keep making leaky boats. For instance, at great expense, the spar could be custom manufactured with a welded in aluminum dam inside at the lowest halyard exit, or an epoxy dam or the like. For outside leaks, the spar could have a welded on skirt with a matching labyrinth seal profile integral to the deck.
It doesn't have to leak, that's the point.
The question is how bad does the leak bother you? $5000 bad?
Perhaps a more well designed mast boot is in order. If it was sealed at the top with a hose clamp and there was a steel ring bolted to the deck, a UV resistant boot would be easy to design. It's just the extra bother and expense that stops these designs from being realized.
Along with the fact that my mast is deck stepped.
tager is offline
post #26 of 28 Old 03-31-2010
I agree totally w/ Giulietta!
quahaugger is offline
post #27 of 28 Old 03-31-2010
Moderator
Jeff_H's Avatar
Its funny, I had a conversation about this subject with Dudley Dix last week. I had mentioned my idea of creating a moment connection at the deck so that I had a deck stepped mast that behaved like a keel stepped mast. He told me that he had used the balloon and epoxy trick very successfully on one of his boats. While that does not solve the issue of being able to jetison a lost mast at sea before it holed the boat, it at least stopped the water coming down the mast.
To avoid the issue that SD raised, if foam is used, it needs to be a closed cell foam so that it does not tap moisture against the mast. (Not all spray foams are open cell.)
I have watched for leaks around my mast boot, even when I try hosing it at full power, and it generally does not leak. I typically loosen the clamp and boot and recaulk it with silicone every couple years and as a result leaking at the boot has not been a problem.
Jeff_H is online now
post #28 of 28 Old 03-31-2010
The MC is wood so fresh water leaks are a concern. This is how the man who built the boat dealt with water in the mast. He drilled a hole 8” above the bottom of the mast and inserted a PVC fitting. Then plugged below that with foam. Water is stopped by the foam, goes out the drain and is collected in a jug. This does not solve any mast boot leaks but I have emptied that jug many times so it is keeping some of the water out of the bilge. Dan S/V Marian Claire
marianclaire is offline
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
Mast types...? Through deck on deck...? marinesniper General Discussion (sailing related) 41 02-02-2007 09:15 AM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
what mast? jrwright Boat Review and Purchase Forum 3 03-14-2004 08:19 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
